WTT: JDM 99 EK H22 SWAP FOR CRX
Delete this form please ----------------------->SOLD<--------------------------
Thanks HT
Modified by b18a2705 at 10:03 PM 1/8/2007
Thanks HT
From: the greatest landscape architect is pictured above, gotta love the lack of home land security, socal
interested in trading for a 1989 black crx si.
heres some quick specs..
stock black
stock d16a6
hf tranny
lowered on tokico blues and neuspeed race springs
jimfab cross member
91 ex sedan hubs on da calapers w/ brembo rotors
heres the kicker...
the stock motor wasn't suppose to be swapped back in. the motor that was originally suppose to be there was is my gsr. the setup currently stands as:
94 gsr bottom end
obd1 stock b16 head
itr intake manifold
aftermarket throttle body (about 61-63 mm) not quiet sure
hondata intake manifold gasket
single layer head gasket
skunk2 cam gears
brand new water pump, oil pump, timing belt all from honda
b16 cable transmission with oem lsd (grinds a little in 3rd)
hasport polyurethane motor mounts
pre-cut shift linkage
axles + half shaft
chipped p28 ecu
let me know if your interested. i'll get pics as soon as i find my digi cam =/
stock black
stock d16a6
hf tranny
jimfab cross member
heres the kicker...
94 gsr bottom end
obd1 stock b16 head
itr intake manifold
skunk2 cam gears
axles + half shaft
chipped p28 ecu
