Emergency Brake Light
Old Dec 3, 2006 | 07:15 PM
GoCarInteg's Avatar
Default Emergency Brake Light
My girlfriends prelude is acting up a little bit and just wanted to see if any of you had the same problem.
On cold mornings (especially if the car isn't warmed up yet), the e-brake light stays on with the brake off. Eventually after the car warms up, it'll turn off.
I'm assuming it's not the little pin that turns the light on because when you put the e-brake down, the "brake" light on the dash becomes a little more dim. Has anyone had this problem before? If so, how do you fix it? Thanks!
Old Dec 3, 2006 | 07:17 PM
M2B4's Avatar
Default Re: Emergency Brake Light (GoCarInteg)
dude read the thread above yours...
edit: below it now...
Old Dec 3, 2006 | 07:24 PM
InvaderTrax's Avatar
Check your (her) brake fluid level
Old Dec 3, 2006 | 08:46 PM
ulanky's Avatar
Default Re: (InvaderTrax)
Here you go dude. Buy thses parts:
OK I looked it up and the is the jist of it.
Service Bulletin 03-078
Affects
96-00 Civic
97-01 CRV
97-01 Prelude
98-02 Accord
Parts need to fix the problem.
Filter part #46666-S04-J02 List of $5.08
Float part #46662-S84-999 List of $1.92
Try that and it should fix the problem
btman
Oct 12, 2007 06:11 AM
dynamo
Jan 11, 2007 11:27 AM
intech
Nov 17, 2005 02:44 PM
ponzarelli
Dec 30, 2002 10:42 PM
