D15B in a CRX
Old Dec 3, 2006 | 07:01 PM
QuickRexSi21's Avatar
Default D15B in a CRX
im putting a 1.5 L D15B vtec-e in my crx, just wondering if anyone has a wiring diagram so that i can wire it?
heres the CRX
heres the engine...
im putting a Si Cable tranny, clutch and flywheel, instead of getting the hydraulic/cable conversion..... im pretty sure the stock mounts will work... cleaning motor tomorrow, gonna post more pics of everything else tomorrow.
Old Dec 3, 2006 | 08:00 PM
STREETWERKZ's Avatar
Default Re: D15B in a CRX (QuickRexSi21)
why the vtec- e?
Old Dec 4, 2006 | 10:27 PM
Default Re: D15B in a CRX (STREETWERKZ)
its the only motor i have in the garage that runs...so instead of buying one, just make that run and just sell it.... i know its not a fast motor swap or anything...just want it to run... plus it gets 55 mpg on the highway, thats so awsome. with gas prices going back up
Old Dec 4, 2006 | 10:51 PM
Rywire's Avatar
what ecu do you plan to use?
Old Dec 5, 2006 | 01:29 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: D15B in a CRX (droppedcrxsi)
http://www.ff-squad.com/technet/wiring.obd1.htm
you're gonna have to convert to obd1 and then at least wire VTEC, VTEC pressure switch, and some extra O2 wiring for the 5 wire if you use the D15's correct ECU
Old Dec 5, 2006 | 05:12 PM
Rywire's Avatar
Default Re: D15B in a CRX (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/technet/wiring.obd1.htm
you're gonna have to convert to obd1 and then at least wire VTEC, VTEC pressure switch, and some extra O2 wiring for the 5 wire if you use the D15's correct ECU</TD></TR></TABLE>
well, if he uses the d15z1 ecu its not that ez, thats why I asked.... Few more things to wire up that you fail to mention
Old Dec 6, 2006 | 02:37 PM
i was going to use the D15 ECU tht came out of the 93 vx hatch. isnt there a plug and play method? rywire perhaps??
Old Dec 6, 2006 | 03:13 PM
Rywire's Avatar
I do make a harness for the z1 ecu... give me a call or pm. Basically there is seven extra wire for the 02 sensor, egr, vtec, vtec oil, and some other light changes, and of course converting to obd1. its kinda a pain in the ***, but totallt doable.
Old Dec 6, 2006 | 03:14 PM
schardbody's Avatar
no plug and play, if it where me, i would just run a chipped ecu, set vtec around 2800rpm high load, and around 3200rpm low load.
disable the o2 heater, and run it like that, good for 35+mpg with the SI trans.
oh wait.......... that is what i did.
Old Dec 6, 2006 | 03:47 PM
Rywire's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">no plug and play, </TD></TR></TABLE>
I guess you didnt read what I said
Old Dec 6, 2006 | 04:25 PM
schardbody's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">I guess you didnt read what I said </TD></TR></TABLE>
i sure didnt, look at the post times, LOL, we were typing at the same time, thats awesome that you can build a harness that has all the EGR, and wideband stuff though, you should advertise that stuff.
wink wink.
Old Dec 8, 2006 | 06:16 PM
thanks for all your help guys,
heres what happened, i looked at everything and said "FCK IT!" some guy crashed a 89 Si, so im pulling that motor out, putting it in my crx, and hes gonna buy my crx for 2500. he wants his seats in the crx, so im gonna have a pair of Si Seats for sale soon, along with a whole lot of other parts. i cant believe im selling my crx but i gotta move out, and i cant take everything with me. so goodbye Rex, ill get another one again....one day
crx-w-b18c5
Sep 25, 2010 12:50 PM
perseverance
29
Jun 5, 2007 07:25 AM
perseverance
Mar 3, 2007 03:26 AM
Jeff
Jan 8, 2006 04:16 AM
88mugencrx
Aug 12, 2003 12:37 AM
