Coolant problem???
Old May 10, 2002 | 07:17 AM
Cosworth's Avatar
Default Coolant problem???
Car: '93 VX
Problem: Even when the temperature **** is in the "COLD" area, it still blows warm/hot air. It doesn't matter if the air is recirculating or getting it from outside (even when cold outside).
What could I do to remedy the situation?
btw, my stock temp gauge is working properly and the motor doesn't over heat.
Old May 10, 2002 | 07:22 AM
sgT's Avatar
sgT
Default Re: Coolant problem??? (Cosworth)
sounds like the valve for the heater core is either stuck or broken.
ninjaturtleEG
Jan 15, 2010 11:21 AM
Fo-Do Fanatic
Nov 21, 2009 09:42 AM
nihad
Feb 11, 2007 02:08 PM
Cosworth
May 10, 2002 10:04 AM
