Half-Radiator for CRX
So here's the scoop,
I've got an 89' CRX that i've swapped a B18 LS into. It's receiving a turbocharger and the works, stock motor.
I need a half-size radiator. That, and my current full-size original radiator leaks.
Any suggestions? I'd prefer a radiator that's aluminum, and that i don't have to ghetto-lean for it to fit right.
Anyone rocking a custom radiator? How much do those run?
thanks,
richard
thanks,
richard
I am curious abou this as well. I am looking for an aluminum half radiator too. I heard the EG radiators were too tall? Can anyone varify this? Also where can you buy a aluminum half radiator for a CRX? I know fluidyne has them but there the exact same price as the full radiators which I personally think is BS! Any help??
Go with the NEON radiaotor mentioned above or get a crossmember that allows you to correctly use an EG radiator. That's pretty much your only two options unless you want to pay $$$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster »</TD></TR><TR><TD CLASS="quote">Go with the NEON radiaotor mentioned above or get a crossmember that allows you to correctly use an EG radiator. That's pretty much your only two options unless you want to pay $$$$</TD></TR></TABLE>
I forgot to mention that I have the Z10 Front Traction bar/crossmember so I can use a EG radiator. Where can I pick up one of those in aluminum for cheap?
I'm not sure if the Z10 allows you to use an EG or not. I know the LSD and innovative ones do. If not you could probably fab up some tabs to make it work pretty easily. You can get a dual core OEM eg radiator from a Del Sol vtec or get on ebay and get an aluminum radiator off of there.
Ebay has a lot of half radiators for 92' hondas and up.. they only have a couple for 88 -91 .. but its worth a browse
http://motors.search.ebay.com/...&fgtp=
We sell EG Dual core radiators for $50, great quality, used them on a turbo car and never had an issue. They will not just bolt into a crx chassis, you need to make brackets for the bottom and the top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ »</TD></TR><TR><TD CLASS="quote">does the neon half size radiator bolt right on? what do I need to make it work?
oh ya and what year do those come out of?</TD></TR></TABLE>
Not the best picture of the radiator, but I think you can see the fitment. It's a 95-99 Neon NON-A/C (<--very important).
crxmadness
19
Dec 2, 2009 10:48 PM
