Are these problems normal for the 5th gen Accords?
Old Dec 3, 2006 | 04:21 PM
EvenStar's Avatar
Default Are these problems normal for the 5th gen Accords?
I am currently facing these problems on my CD7 Accord.
+ Hard to close in passenger door (you actually have to slam it in order for it to lock).
+ In order for the drivers side door to open, you have to push the door handle then pull up HARD, not like other regular car doors (where you just pull up gently).
+ When I insert the key and start the car, the doors automatically lock. (I guess this one isnt bad at all).
+ When I turn off the ignition, the passenger door automatically open for me.
+ I have to manually lock the driver side door always.
+ Driver side street headlight does not work, but high-beam works perfectly.
I bought it from a previous owner if that matters. Any solution on how to fix these? Or are they just common?
Old Dec 3, 2006 | 04:53 PM
mtnwkr's Avatar
Default Re: Are these problems normal for the 5th gen Accords? (EvenStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">
So when you shut off the car the door just pops open?
Old Dec 3, 2006 | 04:56 PM
EvenStar's Avatar
Default Re: Are these problems normal for the 5th gen Accords? (mtnwkr)
I meant, the passenger side locks pop open.
Old Dec 3, 2006 | 05:32 PM
89POS's Avatar
you have a short and wiring issues.
1.the doors arent suppse to auto lock, unless u have an aftermarket alarm n dont know it.
2.. go to a body shop if you cant do it yourself and have the doors adjusted.
3. you need the latchassembly on the drivers side. they tend to go bad. if your handy take it out oil n clean the connections b4 you replace it. might save some money.
Old Dec 3, 2006 | 06:29 PM
EvenStar's Avatar
Default Re: Are these problems normal for the 5th gen Accords? (89POS)
oh ok thanks. yeah, the car did come with an aftermarket alarm, so that may be toggling the auto lock.
Old Dec 4, 2006 | 03:23 AM
Cory man's Avatar
None of the problems you listed are common. The misaligned doors tells me it has previous collision damage. hth
Old Dec 4, 2006 | 06:36 AM
mtnwkr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">oh ok thanks. yeah, the car did come with an aftermarket alarm, so that may be toggling the auto lock.</TD></TR></TABLE>
Yeah, sorry for the joke above.. Most alarms will auto lock when you start the car and unlock when you shut it off..
About the drivers door lock, you know you have to hold up the handle when you hit the lock button right?
Old Dec 4, 2006 | 04:21 PM
EvenStar's Avatar
Yes I remember now. It was on my 85 Accord as well (pull the handle then lock). I never knew it would still be up to this gen. Is this method only made for the Honda Accord?
Old Dec 4, 2006 | 07:56 PM
soon2bdropped's Avatar
not really some cars beside honda u hav to pull the handle and in order to lock the driver side without a key
sikpupy
Oct 20, 2018 01:54 PM
CivicIvo
Oct 10, 2017 04:14 PM
Zackbreakiron
Honda Civic (2006 - 2015)
Aug 6, 2008 07:36 AM
JTTeG_X
Audio / Security / Video
Jun 26, 2005 09:44 PM
95sihb
Jan 3, 2003 08:27 PM
