storing car for winter what do i need to do??????
just like the title says storing car for the winter what do i need to do to keep the engine in good shape till summer? thankx
You could pull the plugs and put just a little motor oil in each hole .This will keep the walls coated .Drain the fuel and put the car on stands. If you are going to be around the car and not out of town ,start the car and run it for a while ,hell even drive it if it is street legal.
yuo can go to your local auto part store and get this **** that you put in the gas (dont remember what its called) it keeps anything from freezing in the tank or lines. if you just park it the wqay it is just start it twice a week and let it run for 15 min you will be fine. i would change all fluids know and in the spring
dan89crxsi
16
Sep 24, 2006 01:22 PM
petrv
Mar 7, 2006 03:02 PM
