Pic Request: 205/50/15 Tire of 00 Si Wheel
Old Dec 3, 2006 | 11:15 AM
projectegr's Avatar
Default Pic Request: 205/50/15 Tire of 00 Si Wheel
As topic states, I would like to see some nice shots of a 205/50/15 tire on a 00 Si wheel. The vehicle is a 00 Civic Si. Thanks.
Also what is the offset on these wheels?
Old Dec 4, 2006 | 12:07 AM
vtecsi00's Avatar
Default Re: Pic Request: 205/50/15 Tire of 00 Si Wheel (projectegr)
offset is 45mm and the 205/50r15 is a little shorter in height than the stock 195/55r15
Old Dec 4, 2006 | 02:07 AM
projectegr's Avatar
Default Re: Pic Request: 205/50/15 Tire of 00 Si Wheel (vtecsi00)
Thanks I appreciate it. Someone on here recommended 205/50/15 or 195/55/15 for the Si. I wanted the lower profile but 195/50/15 seemed too small.
Old Dec 4, 2006 | 06:11 AM
Mike_C's Avatar
i've had 195/50/15, 195/55/15, and 205/50/15 on my si wheels.
195/50/15 looked the best and had no rubbing issues, but also throws off the speedo a little bit. i don't particularly care about my speedo being off.
195/55/15 is the "correct" size, but it has a little too much sidewall for me. i'm currently running this size with some all-seasons on my beater.
205/50/15 was the best size for me at the track, but also rubbed a little bit.
you'll be fine with all the sizes... it basically comes down to your own preference.
Old Dec 4, 2006 | 08:18 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectegr &raquo;</TD></TR><TR><TD CLASS="quote">Thanks I appreciate it. Someone on here recommended 205/50/15 or 195/55/15 for the Si. I wanted the lower profile but 195/50/15 seemed too small.</TD></TR></TABLE>
195/55-15 is the same size and outer diameter as the stock tires. 205/50-15 is 1.6 percent smaller in diameter.
I would not get 195/50-15. It is 3.3 percent smaller in diameter, and that's quite a big difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">i've had 195/50/15, 195/55/15, and 205/50/15 on my si wheels.</TD></TR></TABLE>
The best matching tire size depends on which car you have. For example, 195/50-15 is the best match to the stock outer diameter for CRXs, del sols, and pre-'96 Civics, but 195/55-15 and 205/50-15 are the best match to the stock outer diameter for Integras and '97-00 Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">you'll be fine with all the sizes... it basically comes down to your own preference. </TD></TR></TABLE>
Your preference should be based on an understanding of the trade-offs. Tires with a diameter larger than stock may rub, will cause slower acceleration, and will add error to the speedometer and odometer. Tires with a diameter smaller than stock will also add speedo/odo error. Either way, the tires may look odd. As a general rule, it's hard to go wrong with tires as close in diameter to the stock size as possible.
Old Dec 4, 2006 | 08:39 AM
Mike_C's Avatar
Default Re: Pic Request: 205/50/15 Tire of 00 Si Wheel (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The best matching tire size depends on which car you have. For example, 195/50-15 is the best match to the stock outer diameter for CRXs, del sols, and pre-'96 Civics, but 195/55-15 and 205/50-15 are the best match to the stock outer diameter for Integras and '97-00 Civics.</TD></TR></TABLE>
right, he has an '00 civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Your preference should be based on an understanding of the trade-offs. Tires with a diameter larger than stock may rub, will cause slower acceleration, and will add error to the speedometer and odometer. Tires with a diameter smaller than stock will also add speedo/odo error. Either way, the tires may look odd. As a general rule, it's hard to go wrong with tires as close in diameter to the stock size as possible.</TD></TR></TABLE>
right, and i gave him the tradeoffs.
Old Dec 4, 2006 | 04:29 PM
projectegr's Avatar
Default Re: Pic Request: 205/50/15 Tire of 00 Si Wheel (Mike C)
Thanks for the information. NSX gave some good info in a post in another thread that basically said the same thing. I'm looking for speedo accuracy and clean look. I chose 205/50/15. Thanks
TOO MUCH TORQUE
Nov 15, 2008 12:59 PM
ILOVEGIRLS
23
Mar 8, 2007 02:04 PM
HiPhOpHeADs
Sep 14, 2006 10:08 PM
Ragezero76
Jul 13, 2003 06:31 AM
