205/55/15 instead of195/55/15
are there any disadvantages for running a tire slightly wider than oem? this is going on a 00 SI with stock SI rims. thanks
Re: 205/55/15 instead of195/55/15 (ILOVEGIRLS)
Going to a 205 series tire is a very common upgrade on a Si, but you would need to get 205/50/15 or your speedo will be off. What kind of tire are you thinking about getting?
<-------Bridgestone Potenza RE750
I'm a Jackass
Re: 205/55/15 instead of195/55/15 (RiceKillinSI)
the 55's you may encounter rubbing most of us are running the 50.. i like the wider tire myself
Re: 205/55/15 instead of195/55/15 (Takymoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takymoto »</TD></TR><TR><TD CLASS="quote">the 55's you may encounter rubbing most of us are running the 50.. i like the wider tire myself</TD></TR></TABLE>
no 55's most of the time wont rub.
HT White Ops
I used to run 205/50/15 Bridgestone RE750's, but they had some really bad camber wear when I got them, and that ****'s like rust. Once it starts, there's no stopping it.
I now run 195/50/15 Fuzion ZRi (made by Bridgestone, very similar to the RE750). They're fantastic, but I miss running 205's.
Re: (blackhatch96)
u want the smallest sidewall possible so go with the 50 the smaller the sidewall the less roll there will be around high speed cornering
I'm a Jackass
Re: 205/55/15 instead of195/55/15 (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson »</TD></TR><TR><TD CLASS="quote">
no 55's most of the time wont rub.</TD></TR></TABLE>
and i said they MAY rub..... like you said MOST of the time they wont... same thing bud
205/50/15 will have almost the same sidewall width as 195/55/15, cause the middle number reflects the precent of the width that the sidewall is tall. The 195's will have a 107.25mm sidewall while the 205's will have a 102.5mm sidwall. Thats about half a centemeter difference, which is not that much.
Re: 205/55/15 instead of195/55/15 (turnsignalandy)
i have 205/50/15s on my stock SI rims.. no fitment/rubbing issues.. and like stated above, more contact surface is better..
Re: 205/55/15 instead of195/55/15 (DEL HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEL HATCH »</TD></TR><TR><TD CLASS="quote">i have 205/50/15s on my stock SI rims.. no fitment/rubbing issues.. and like stated above, more contact surface is better..</TD></TR></TABLE>
Re: 205/55/15 instead of195/55/15 (cambopheonix56)
i ran 195/55/15 on si wheels on my eg. they did rub when i would make hard turns etc but it wasnt that bad. my speedo was deff off a good 3mph. and i tested that with the road radars. I would do 60 and it would read 63.
I recommend 205 50 15s over the 195 55 15. duno how to explain it, but it just felt more normal. call it a butt dyno but i was happy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS »</TD></TR><TR><TD CLASS="quote">hey thanks guys!! 205 it is..now what tire is a good one? </TD></TR></TABLE>
what do you plan on doing??
Auto-X Falken Azenis 615s or Kuhmo MXs
Daily Driving I personally like the Yoko AVS ES100 cause they last long and are great for wet weather and dont give any vibration or road noise.
All-seasons.... Dunno, never ran anything
Winter Deff the winterforce tires.. love mine.
1 Post
Re: (blackhatch96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatch96 »</TD></TR><TR><TD CLASS="quote">wider is better! more contact surface good my friend
Plz stop misinforming the uninformed... Now read this once and read twice if you have too wider is not better.... better compound is better. Don't waste your money on a wider tire when could of just got a better compound.
Now 195-55-15 is the right size for your car but you can also run the 205-50-15 which while not mess up your speedometer or odometer and not have rubbing issues. Also 205-55-15 is way to big and you will have rubbing issues and inaccurate speedometer and odometer as well as poor acceleration and handling.
If you need any help on picking tires please come check out the tire and wheel section on honda-tech we will be glad to help you.
1 Post
Re: 205/55/15 instead of195/55/15 (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">
Winter Deff the winterforce tires.. love mine.</TD></TR></TABLE>
For auto-x I agree with the RT-615 but if you plan on daily driving on them you will be changing them more often then other tire. Also they suck in the rain.
For Daily Driving the ES100 are good but compared to the Kumho SPT they come second to them. The SPT did better then the ES100 in every category tested. Also the SPT's are cheaper! They are the best bang for the buck tire out now!
I also recommend the Yoko ES100s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">i ran 195/55/15 on si wheels on my eg. they did rub when i would make hard turns etc but it wasnt that bad. my speedo was deff off a good 3mph. and i tested that with the road radars. I would do 60 and it would read 63.
I recommend 205 50 15s over the 195 55 15. duno how to explain it, but it just felt more normal. call it a butt dyno but i was happy.</TD></TR></TABLE>
That makes sense. I have SI wheels and I run 195/50/15 on mine and the speedo is 5 mph off. As I also tested this via radar trailers.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
205/50-15 will be 1/2 shorter then stock 195/55-15, and will cause the speedo to show a faster spee then you are actually traveling. on the other side, 205/55-15 will be taller, and cause the speedo to show a lower reading then you are actually traveling. what you need is 215/50-15
195/50-15= 22.67
205/50-15= 23.07
195/55-15= 23.44
215/50-15= 23.46
205/55-15= 23.87
275/35-15= 22.57 (just threw this in there for ***** & giggles, my new track tire size)
195/50-15= 22.67
205/50-15= 23.07
195/55-15= 23.44
215/50-15= 23.46
205/55-15= 23.87
1 Post
Re: 205/55/15 instead of195/55/15 (Rodney)
I do agree with the 215 being closer to stock the problem is that they probably won't fit on an Si wheel. Also I believe some rubbing will be an issue. That is why the 205 is a better candidate.
2000GSR
01-31-2006 07:45 AM
vtec_yosh
02-09-2004 12:48 AM
