Suspension & Brakes Theory, alignment, spring rates....
energy suspension install?
Old Dec 3, 2006 | 10:15 AM
hondaboy90's Avatar
Default energy suspension install?
ok i just got new outer tie rod boots and new UCA boots from energy suspension
now how the do i install them, their not like the stock ones
Old Dec 5, 2006 | 09:21 PM
Graham S.'s Avatar
Default Re: energy suspension install? (hondaboy90)
There should be a small thin retaining ring around the old boots. Remove that ring and install the new boot using the old retaining ring. Should fit up just the same.
Old Dec 6, 2006 | 02:28 PM
hondaboy90's Avatar
Default Re: energy suspension install? (Graham S.)
do i need to fill it back up with anything cause the stock onee had a bunch of grease or something in it
if so what do i fill it with and how as well
Old Dec 6, 2006 | 02:54 PM
94eg!'s Avatar
#1 Super Guy
Loved
Just put a glob of grease along the inside wall of the new red boots. Any suspension grease from the autoparts store will do. Then install it on the stud & put the old cir-clip back on.
Old Dec 6, 2006 | 03:03 PM
hondaboy90's Avatar
Default Re: energy suspension install? (94eg!)
ok i went out and looked at em and the old ones have a groove for the clip to go around and the new ones from energy suspension dont have the groove for it to slip over
so what now?
Old Dec 6, 2006 | 05:17 PM
94eg!'s Avatar
#1 Super Guy
Loved
Looks like you just don't use the circlip, and hope the boot is tight enough that it doesn't come off. Waste of time IMO. OEM rubber would be better and probably cheaper too...
Old Dec 6, 2006 | 05:31 PM
Tyson's Avatar
ES boots dont use any circlip.
just fill em with grease and squich them in. wipe off any excess grease after youve tighten it down.
dont worry, nothing is getting inside of the boot.
theyre definately more durable than the stock rubber boots. but they do have a lower melting temp than rubber. so not good for track use. street is fine.
having a poly boot is going to do nothing for performance. not even sure why they bother. i liked them because i could whack a bit more indiscriminately when popping off the balljoints, not having to worry about puncturing the boot. thats pretty much the only plus.
yes, new rubber boots are cheap.
Old Dec 6, 2006 | 11:06 PM
dvp's Avatar
dvp
Default Re: energy suspension install? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">ES boots dont use any circlip.
yes, new rubber boots are cheap.</TD></TR></TABLE>
HELLO, it's poly, you're supposed to have it everywhere for the performance gain.,....DUH!!!
Do they cost more than the stock ones?
DC2-ProdUcTiOnS
13
Sep 22, 2009 08:49 AM
superslow-oto
Suspension & Brakes
Jul 27, 2006 10:55 AM
hackish
34
Jul 11, 2006 08:05 PM
sleedawg
Jan 4, 2003 04:27 PM
McLaren
Mar 18, 2002 06:27 AM
