cranking no start on b16a.....help...
Old Dec 3, 2006 | 10:05 AM
vw eater's Avatar
Default cranking no start on b16a.....help...
ok hers the story...was driving and car just died at a stop sign and would not start so i get it to my house and start checking connectors and what not and i find out i have no spark, is there a way to check the distrubitor? i tryed grounding out one of the plugs but i didnt see any spark....thanks and no stupid comments
Old Dec 3, 2006 | 10:58 AM
STREETWERKZ's Avatar
Default Re: cranking no start on b16a.....help... (vw eater)
same happened to me once... alternator belt tore off somewhere, so i was running off the battery.
it would crank, but not turn over.
Old Dec 3, 2006 | 11:05 AM
vw eater's Avatar
i checked the belts and there fine, i will go check on the timing belt, but i think its becuse of no spark...
Old Dec 3, 2006 | 11:16 AM
Crx Jimmy's Avatar
open the dizzy cap see if the rotor fell off happens all the time, also check the alternator sol fuse. its the 10amp fuse between two 15 amp fuses in the top left of the fuse box
Old Dec 3, 2006 | 11:21 AM
Default Re: cranking no start on b16a.....help... (Crx Jimmy)
rotor screw is a good thing to check.
good thinking jimmy.
Old Dec 3, 2006 | 12:03 PM
vw eater's Avatar
ok i fixed it!!!! it was the coil.. i had a extra obd0 distrubitor from my other crx that i converted to obd1 so i switched the coils out and started right up..good thing i dont throw away my old parts...
sproket13
Aug 12, 2024 05:52 AM
jnemci
11
Jun 22, 2009 08:21 AM
DACteg
May 15, 2007 06:35 PM
GoCarInteg
31
Apr 12, 2006 09:06 PM
Proper
Sep 13, 2002 09:29 AM
