Eibach wheel spacers
uhhh.....horizontal. i dont see how it can push it up vertically. lol.
its like this... without spacer 0=......with spacer 0:=
0 is the wheel
= is the axle
: is the spacer
lol. dont know how much that helps.
0 is the wheel
= is the axle
: is the spacer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 »</TD></TR><TR><TD CLASS="quote">Anyone here ever install wheel spacers on there car. exactly what do they do.</TD></TR></TABLE>
They basically allow you to use wider wheels and bigger tyres in situations where the setup would otherwise rub on a trailing arm or inner fender.
Wheel spacers that are sold specifically for racing use will be safe enough for use on the road.
Many Honda Challenge racers will have to use spacers on their DC and EG cars when they go to 225 series tyres or wider.
Bear in mind that if you space your wheels too far out, you could introduce problems in other areas. For example if you space your wheels too far out on a car that's basically a daily driver, and you are using stock spring rates, you could end up rubbing on the <u>outer</u> part of the fender.
another thing to look for when buying spcers to to see if they are hub centric or not. try to get hub centric ones but if that isnt possible then then remember to torque down your wheels while your car is still up in the air and remember the criss-cross star pattern.
EH3Civic
Mar 4, 2006 10:25 AM
