cabin filter??
Old Dec 2, 2006 | 11:28 PM
MugenSiR's Avatar
Default cabin filter??
trying to locate the cabin filter in my gf's 04 Accord V6 EX Sedan, anyone know where that is???
Old Dec 3, 2006 | 04:20 AM
Duane_in_Japan's Avatar
Default Re: cabin filter?? (MugenSiR)
I am going to say that it is behind the glove box, I believe that the center lower console and the side panel of the dash (open the passenger door) and the passenger knee bolster need to be removed or have to be slightly disassembled then remove the entire glove box. You may have two filters stacked on top of each other. You may also have the option to upgrade to better hepafilters for better pollen control if your family needs it.
This was fact on a '98.
Old Dec 3, 2006 | 03:12 PM
Perfectionist's Avatar
Most newer models only require that the glovebox door be dropped down. Squeeze the plastic clips on the door stops on each side of the glovebox to release and remove them. The door will swing down. You will see the blower housing and a flap you can easily remove without tools. This exposes the filters. Pull the first one out and slide the second one over to remove it.
Blazinmiller
Aug 10, 2010 11:15 AM
01_civic
Jul 4, 2008 09:52 AM
Homesickelian
Nov 24, 2006 04:08 PM
96teggynonVtec
Feb 18, 2006 02:22 PM
teg95
May 22, 2002 01:16 PM
