FS: Fully Built SR20DET, Carillo, Wiseco, Crower, etc!
Old Dec 2, 2006 | 11:01 PM
Drag_S14's Avatar
Default FS: Fully Built SR20DET, Carillo, Wiseco, Crower, etc!
I've decided to go a different direction with the car, so the entire longblock is up for sale. The oldest parts on this engine have 1500mi on them, some have less than a couple hundred. This engine has never burned a drop of oil, and does not leak anything. I have cut corners in the past and it always caught up to me, so I took ZERO shortcuts with this engine. If anything didn't look perfect, it was replaced.This engine will easily take 600+ hp without breaking a sweat.
Specs:
Code:
Greddy RAS			$  90
Crower VS/ Ti RET		$ 380
HKS 272	Step 2			$ 440
Tomei Solid Lifters		$ 240
HKS Cam Gears			$ 300
Cometic	Headgasket		$  75
ARP Head Studs			$ 145
ARP Main Studs			$ 100
Carillo A-Beam Rods		$ 750
Wiseco 9:1 86.5mm		$ 485
New Timing Chain		$  75
New Rockers			$ 200
New Tensioner			$  75
New Guides			$  75
Misc Gaskets			$  75
Clevite Bearings		$ 100
New OEM Nissan Oil Pump		$ 250
New OEM Nissan W/Pump		$  75
Greddy W/Pump Pulley		$  75
ATI SuperDamper Crank Pulley	$ 425
Head/Intake Manifold Porting	$ 450
Greddy Intake Manifold		$ 450
Thermal Intake Gasket		$  40
Alternator			$  50
Machine work-Bell Motor Service	$1400
Align Hone - ERL Performance	$ 250
Core Engine			$ 750
Cam Angle Sensor		$ 150
Total:				$7970
This engine has never seen over 18psi or ever been on race gas. The highest I've revved it was about 9000. With the T4/T61, on 18psi, this engine was likely making around 350-400whp. The solid lifter conversion was done by Tom Bell @ Bell Motor Service, along with the rest of the machine work. The align hone on the main caps was needed because of switching to the ARP main studs, and was performed by ERL Performance. This engine is very strong, and besides a couple rocker arms, I haven't had any problems out of it. The rocker arm issue has since been addressed and should not happen again.
As you can see by my list above, I have roughly $8000 invested into this engine, probably more that I'm forgetting. I'm asking $6000 for the engine as it sits. I will NOT part out the engine, but I will work with you if you do not want the intake manifold or something else external to the engine.
PM me or email @ blakebonkofsky@geektuned.com
Pics:
Old Dec 4, 2006 | 07:47 AM
Drag_S14's Avatar
Default Re: FS: Fully Built SR20DET, Carillo, Wiseco, Crower, etc! (Drag_S14)
Old Dec 6, 2006 | 08:53 PM
Drag_S14's Avatar
TTT
Old Dec 20, 2006 | 09:39 PM
Drag_S14's Avatar
bump!
boostedeg302
Mid-Atlantic (Sales)
33
Feb 9, 2010 09:46 AM
boostedeg302
Southeast (Sales)
Feb 9, 2010 08:16 AM
boostedeg302
Jan 14, 2010 12:49 PM
Drag_S14
Dec 6, 2006 08:53 PM
AutoLab
Jan 1, 2006 07:45 PM
