Knocking noise from suspension or drive train...
Old Dec 2, 2006 | 10:17 PM
SimplyTron's Avatar
Default Knocking noise from suspension or drive train...
I have a 90 CRX Si with a b16a, Y1 transmission with LSD, H&R sport spring stock shocks. Whenever I shift or let off the gas then get back on i get this knocking noise from the front end. From what I know which isn't all that much I think it is either the intermediate shaft bearing, throw out bearing, or the shocks. It kind of makes the same noise when I hit bumps. My shocks are definitely blown. But could shocks make that kind of knocking noise when I shift or get on and off the gas? It is only when it is slightly aggressive, I can baby the throttle and clutch and get it not to make the noise.
Old Dec 2, 2006 | 11:47 PM
peanut butter's Avatar
Default Re: Knocking noise from suspension or drive train... (SimplyTron)
I had something similar and it was my front motor mount had come loose, I would check your motor mounts...but it could also be something else.
Old Dec 3, 2006 | 08:35 AM
SimplyTron's Avatar
I dont have a front motor mount but all my mounts are tight as hell. My motor doesnt move at all.
Old Dec 3, 2006 | 08:38 AM
extensioncordy's Avatar
i had the same problem too. it was also the front motor mount. but since u dont have one check your traction bar things. coming off the crossmember mine also came loose once
Old Dec 3, 2006 | 08:46 AM
Tyson's Avatar
a lot of ppl who have reported and solved this similar issue has consistently been either an engine mount issue (loose bolts) or a cracked subframe.
Old Dec 3, 2006 | 09:00 AM
SimplyTron's Avatar
Just went out and checked my mounts both sides are tight but I didnt check the rear. I have a explicit speed traction bar I its tight also. What exactly is considared the sub frame?
Old Dec 3, 2006 | 10:14 AM
Tyson's Avatar
Default Re: (SimplyTron)
be sure to check the rear. thats what i remember as most common.
subframe is the part that holds the steering rack.
Old Dec 3, 2006 | 10:59 AM
SimplyTron's Avatar
Yea I will just didnt have time to get under the car to check the bracket bolts. Any specific point on the subframe or just anywhere above and on the sides of the steering rack?
Old Dec 3, 2006 | 01:13 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimplyTron &raquo;</TD></TR><TR><TD CLASS="quote"> anywhere above and on the sides of the steering rack?</TD></TR></TABLE>
Old Dec 3, 2006 | 04:45 PM
mr_hahn73's Avatar
Default Re: (Tyson)
I would check all the bolts by the spindles and hubs and lugnuts
Old Dec 3, 2006 | 06:14 PM
SimplyTron's Avatar
I just replaced the axles so everything should be tight but ill check that too while Im at it.
KZen
Honda Civic (2001 - 2005)
Jan 21, 2016 04:37 AM
WhiteOnRice
Aug 25, 2007 01:28 PM
TurboEM1
Suspension & Brakes
Feb 23, 2006 02:45 PM
Mike banX
Suspension & Brakes
May 17, 2005 04:37 AM
