Finally tuned! dyno graph inside
Basic run-down of setup consists of
b18c1 block .25 over
11:1 compression
b16 head
pro1 cams
RMF header
AEM 3" intake
Tuned by Fred a.k.a. Cubish here on honda-tech
This was done with no cam gear tuning..anyways im very happy with the results and its a whole different car now
shortly will be back to the dyno with a shortram with bPi flowstack, e-cut open header n some cam gear tuning to hopefully make 200whp..
If not, the run folliwing will be on a little more than a 100shot direct port ne ways
11:1 compression
b16 head
pro1 cams
RMF header
AEM 3" intake
car def feels strong. kinda got to the dyno late so we didnt have much time to mess with the gears (valve cover not cut).. car has an idle air control problem too so it was kinda a bitch to set the timing on the car
the bpi stack, open header, and some cam tuning and it should see over 200
well we were having problems with my IACV so its still not steady...but hopefully by next week or so when we go back with spray..that will be fixed, for he needs to make sure timing is dead on for the nitrous
Pandahatch
37
Oct 2, 2005 06:01 PM
swaytec360
20
Aug 11, 2005 12:46 AM
