Someone ID this harness ?
Ive had this harness laying around for a while now, and dont remember what car it came out of. Can someone shed some light on this. Im including pics of the drivers side main connectors, passenger side main connectors, and the injector connectors.
Passenger side main connector:
Injector connectors:
Drivers side main connector:
Any help with this is greatly appreciated.
by the looks of those fuel injector harness's, it's gotta be to a D series motor, most likely either a CX or a VX, might be DX, not sure exactly.
Its deff a obd1 because of the grey plugs. Could it be a obd1 gsr ? I dont recodnise the triangular connector on the passenger side main connector.
i think you got drivers side and passangers side connectors mixed up
ive never seen a triangular connector like that on the main harness (going to ecu, passanger side)
looks like obd I
looks like obd I
It can't be a teg or civic harness.If you notice,one of the bigger connectors on the driver side should have a cap,but it doesnt.And even if it didnt have the cap on it,you would see like 8 yellow/black wires coming from it. If you notice too on the driver side connectors,the middle plug looks just like the ones they use for the injector resistors on the accords and preludes. Yes it definitely is an obd1 harness.It definitly is not a h22 or h23 harness cuz of that plastic cover on the injector connectors.So that would leave either the prelude s model,or an accord harness,or some jdm harness.
[Modified by aeolus, 10:45 AM 5/10/2002]
I agree with aeolus. It looks like an OBD1 Accord or Prelude engine harness.
The triangle plug and configuration of the passenger/driver side plugs leads me to believe it came from an Accord or Prelude.
This is just an educated guess.
-kenji
-kenji
Those look like DSM style injector plugs. It could be a very clean, factory looking splice (i always try to achieve that whenever i do electrical work)
The drivers side looks to be a standard civic/teg but the pasenger side is unfamiliar, particularly that trapazoidal plug. I have never seen a plug like that on a honda.
Like i said above. it could be a very carefully done custom hack of some sort.
(if it's a Prelude harness that would explain the injector plugs, The ludes still have the low impedence injectors which are supposd to be direct swaps with DSM injectors)
Mike
[Modified by 92sleepR, 2:07 PM 5/10/2002]
Mike
vtec-adykt
Apr 17, 2008 06:11 PM
D3U1LT
Jan 24, 2005 10:47 AM
