Spoon Wires vs. Any other
Old Dec 2, 2006 | 04:01 PM
djtsmith007's Avatar
Default Spoon Wires vs. Any other
Well after reading into the Spoon Plug Wires and seeing they have a small resistance of .04ohms , and since im getting a degree in electronics, i wondered what my (Magnecor) plug wires would ohm out to.
http://robearracing.com/pd_magnecor_10mm.cfm --can be seen here
And the results were really surprising to me. I first mesured the far right plug wire (sry cant member what cynlinder # it is)
I used my Meterman 37XR to do this little test. And just some quick info for some people who may not understand the significance of this. The larger the number of resistane (better know as Ohm's) drop's a larger amount of Voltage. Therefore getting less amount of voltage to the spark plug. So if we had a smaller resistance we would have more voltage going to the spark plug to make a better spark. Im not gonna go into how current is affected, its alot more writing and i know Honda-tech's like to see pictures. So here we go.
Starting at the opposite end from the distrib. cap.
As you can tell the resistance gets smaller as we get smaller in actual lenght of the plug wires. 5.7k Ohms - 3.2k Ohms is WAY larger than .04Ohms. So how much power loss is there actually? There is not telling without an actual dyno between these and the Spoon Wires.
So this is just a post for people to read and maybe help understand a lil more bout their ride. Thanks for readin
Old Dec 2, 2006 | 04:17 PM
Kyoto now's Avatar
Default Re: Spoon Wires vs. Any other (djtsmith007)
interesting, that's a big difference. At my local performance shop they have a display that has all major brand plug wires and measures thier performance. turns out that MSD (the manufacturer of the display, not surprisingly ) had the least resistance of the bunch.
Old Dec 2, 2006 | 04:46 PM
Padawan's Avatar
Darth ModerVader
Nice test, however I'd be interested in seeing the results for the Spoon wires using the same equipment. I suspect their resistance figures would be more than the claimed 0.4 ohms. By the way, I couldn't find the resistance numbers on the Spoon site. Where did you locate them?
Old Dec 2, 2006 | 05:21 PM
JDM_DC4_Fanatic's Avatar
if i'm not mistaken, the link was for the magnacore wires...I could be wrong though. Good test though
Old Dec 2, 2006 | 05:37 PM
Uncle Willie's Avatar
.04 ohms...LMAO. I dont even think that is possible.
All i remember is that if you have over 10k ohms resistance per foot, your wires are shot.
Old Dec 2, 2006 | 05:50 PM
Default Re: Spoon Wires vs. Any other (Uncle Willie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Nice test, however I'd be interested in seeing the results for the Spoon wires using the same equipment. I suspect their resistance figures would be more than the claimed 0.4 ohms. By the way, I couldn't find the resistance numbers on the Spoon site. Where did you locate them? </TD></TR></TABLE>
I finally found where i read that information. Although i was off, its .09 not .04
http://www.inlinefour.com/higtenplugwi.html
Old Dec 2, 2006 | 06:12 PM
SlammedDC2's Avatar
Semper Fidelis
Learn something new everyday, cool test man
I wonder what NGK blues came up as?
Is your device similar to a multi-meter?
Old Dec 2, 2006 | 06:17 PM
bg-33p's Avatar
Default Re: Spoon Wires vs. Any other (SlammedDC2)
You are a smart man, thanks for the information and unlike most threads i feel smarter after reading this one
Old Dec 2, 2006 | 06:20 PM
Default Re: Spoon Wires vs. Any other (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Learn something new everyday, cool test man
Is your device similar to a multi-meter?</TD></TR></TABLE>
Yes it is a mutlimeter. The very top pic you can barely see i can use it to meausre ALOT. Its a $120 meter, and worth every bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">You are a smart man, thanks for the information and unlike most threads i feel smarter after reading this one </TD></TR></TABLE>
Thank you very much. I hope everyone else feels the same
Old Dec 2, 2006 | 06:49 PM
SlammedDC2's Avatar
Semper Fidelis
I also feel the same way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtsmith007 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it is a mutlimeter. The very top pic you can barely see i can use it to meausre ALOT. Its a $120 meter, and worth every bit </TD></TR></TABLE>
I recently got one myself, but have no idea how to use it. I am slowly learning.
Old Dec 2, 2006 | 07:25 PM
TypeRider98's Avatar
very good thread. sharing new information is a
Old Dec 2, 2006 | 08:58 PM
chrisw85's Avatar
i wonder if the stated resistance for the Spoon wires is for the entire lenth or like per mm or something like that; as you said, total resistance increases with length.
Old Dec 2, 2006 | 09:06 PM
Jose-aka-Pedro's Avatar
Default Re: (chrisw85)
Interesting,
Due to this being one a few threads containing technical
information as well as mature technical discussion./
I'd like to see what the POS autozone wires are. :eyes shift left and right:
Just to see the diffrence
Old Dec 3, 2006 | 10:24 AM
Default Re: (Jose-aka-Pedro)
I posted this same topic in the ITR forum and got some good questions and thoughts.
https://honda-tech.com/zero...26891
Thanks for everyones input
Old Dec 3, 2006 | 10:47 AM
Default Re: (djtsmith007)
ALSO. If anybody tries to (for some reason) measure the output voltage out of a plug wire in any way.. DO NOT! It can be VERY dangerous and you can get seriously hurt. Ive seen someone get shocked by a MSD system that wasent careful, and it KNOCKED HIS A** on the ground. So safetly first people
gourley
Aug 10, 2009 03:05 PM
djtsmith007
Dec 3, 2006 11:30 AM
bcrl
Dec 7, 2003 02:00 PM
TypeR0936
May 9, 2002 10:04 AM
itr501
Dec 14, 2001 07:44 AM
