Suspension & Brakes Theory, alignment, spring rates....
need a brake line bleeding order
Old Dec 2, 2006 | 03:05 PM
electriccrayon's Avatar
Default need a brake line bleeding order
I have gotten too many different line order suggestions that my head is spinning now. as agravating as bleeding is, i dont feel up to trying all of the orders ive heard.
its a 92 Civic DX model. please dont reply to me with the order on your own car if it ISNT a 92 civic dx model, or if your guessing. i think ive had enough of that for one day!
Old Dec 2, 2006 | 04:25 PM
Heretic:Si's Avatar
Default Re: need a brake line bleeding order (electriccrayon)
right rear, left rear, right front, then left front. it doesn't matter what kind of car it is, unless it's right hand drive. you start with whatever one is farthest away from the master cylinder and work your way closer with each one you do.
also, maybe you should buy a manual for your 92 CIVIC DX
Old Dec 2, 2006 | 08:48 PM
chrisw85's Avatar
i do it opposite, i start with the closest, so i'm not flushing all the old fluid remaining in the resoivoir back into the rear lines. Flush it out of the closest lines, you have fresh fluid in the resovoir that now goes to the rears. Then I flush the rears. Sometimes I'll go do a quick rebleed on the front. It's worked for me so far. Same thing when I replace the master cylinder, start with the front lines to get any remaining air in the m/c out sooner instead of pushing all the way through the rear lines.
Old Dec 2, 2006 | 09:10 PM
EK k kay's Avatar
Default Re: (chrisw85)
Rear Right, Front Left, Rear Left, Front Right.
Old Dec 3, 2006 | 07:58 AM
PIC Performance's Avatar
Default Re: (EK k kay)
lol I think he's 100% confused now.
Old Dec 3, 2006 | 10:01 AM
byronl's Avatar
rear right, front left, rear left, and front right.
Old Dec 3, 2006 | 12:47 PM
BlueIntegraBoy's Avatar
From the Helms manual...
Old Dec 3, 2006 | 01:24 PM
byronl's Avatar
Default Re: need a brake line bleeding order (BlueIntegraBoy)
which helms did u get that from? My helms for the 92-95 civic shows 1. rear right, 2. front left, 3. rear left, and 4. front right.
Old Dec 3, 2006 | 01:28 PM
Default Re: need a brake line bleeding order (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">which helms did u get that from? My helms for the 92-95 civic shows 1. rear right, 2. front left, 3. rear left, and 4. front right.</TD></TR></TABLE>
92 Civic, or might have been 98-01 Integra. Can't remember.
Old Dec 3, 2006 | 01:34 PM
byronl's Avatar
yea that probably was for an integra, here's a pic from my helms.
Old Dec 3, 2006 | 01:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">yea that probably was for an integra, here's a pic from my helms.
Maybe had to bleed it differently because of ABS.
Old Dec 3, 2006 | 02:44 PM
743power's Avatar
Default Re: need a brake line bleeding order (Heretic:Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">right rear, left rear, right front, then left front. it doesn't matter what kind of car it is, unless it's right hand drive. you start with whatever one is farthest away from the master cylinder and work your way closer with each one you do.
also, maybe you should buy a manual for your 92 CIVIC DX </TD></TR></TABLE>
yea, he should buy a manual so he can recieve the RIGHT information.
The image that byronl posted is how honda recommends bleeding on an eg
HOWEVER, even though I couldn't resist the chance to point that out, I have bled in the "traditional" manner like heretic mentions and it worked as well.
Old Dec 4, 2006 | 01:15 PM
Heretic:Si's Avatar
Default Re: need a brake line bleeding order (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">
HOWEVER, even though I couldn't resist the chance to point that out, I have bled in the "traditional" manner like heretic mentions and it worked as well.</TD></TR></TABLE>
i never stated that was the proper way for HIS car . i told him how i do it. thats how i was trained to do it. i've always done it that way on all cars and never had any problems, ever. either way he needs to buy a manual for his car, then he wouldn't have to ask questions such as this. "chrisw85" says start with the front so you don't flush all the old fluid through the lines, before i start i get all the old fluid out of the resevoir first and fill it with fresh fluid before i even start bleeding them. i don't think any certain way is wrong or right as long as it gets all the air out of the lines.
doceis
Oct 28, 2016 09:27 AM
WhiteOnRice
Suspension & Brakes
10
Nov 3, 2012 03:45 AM
braass91
18
Jul 19, 2012 11:38 AM
94gsxturbo
May 16, 2007 05:01 PM
RICE POLICE SIP
12
Jul 12, 2003 02:19 PM
