Electric Fans Not Coming On When HOT
Old Dec 2, 2006 | 10:30 AM
Def's Avatar
Def
Default Electric Fans Not Coming On When HOT
This is actually for a friend's CRV, but since a B20Z is so close to a B18x I figured I'd get a response here.
The electric fans up front kick on when the AC is on, but they never turn on otherwise, so the water temp starts rising when still. Start driving and it falls right back down so the cooling system is fine(he bled it).
All fuses and relays seem fine, so I think it's a sensor issue.
Where is the sensor located that kicks on the fan at a certain temperature, since that's probably dead? It's been so long since I've owned my Integra that I forgot where it's located(Maybe cylinder head???).
TIA
Old Dec 2, 2006 | 11:28 AM
s2kdre's Avatar
Default Re: Electric Fans Not Coming On When HOT (Def)
jump the coolant temp switch.
Old Dec 2, 2006 | 11:29 AM
s2kdre's Avatar
Default Re: Electric Fans Not Coming On When HOT (s2kdre)
its right behind the distributor on the thermostat housing.
Wyatt Carter
Jun 5, 2017 09:50 PM
hondaccordguy
Dec 10, 2006 07:23 PM
tianporn
15
Feb 20, 2005 10:56 AM
yellowturbo
Jan 7, 2004 02:44 PM
