00 integra oxygen sensors
i need everyone's opinion.
i need a new set of o2 sensors but every autozone/checker's here doesn't have them in stock. not only that but they're quite expensive for a direct fit. i've noticed the universal o2 sensors are a lot cheaper but how safe are they and how hard would it be to make them fit..?
i got a universal on my teg, its real easy, all you do is use the harness off the old sensor make sure the correct wires are going to the right ones, bolt on check for engine light...if none everthing is cool....
also becareful not to mix up the two blacks...you'll see..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 »</TD></TR><TR><TD CLASS="quote">i got a universal on my teg, its real easy, all you do is use the harness off the old sensor make sure the correct wires are going to the right ones, bolt on check for engine light...if none everthing is cool....
also becareful not to mix up the two blacks...you'll see..</TD></TR></TABLE>
what will happen if the 2 black wires get mixed up? since they're both grounds, what difference would it make? just curious, because i had to extend the wires on a oxygen sensor on my car, and i don't know if i mixed up the blacks or not.
As long as I dont have to take out any more Metal Gears
bump i need to know too. I'm in the market to buy new 02 sensors, and the universals are significantly cheaper than the ones that are plug and play
so does it not matter if the 2 blacks are mixed up? what will you see if you do?
blindsk8er1013
Sep 16, 2008 04:38 PM
