Testing waters 1996 honda civic cx hb with gsr swap
I decided to sell my ek cx hb for around 7k. Car is currently at shop, compression was harmed by small amounts of water going into short ram intake. Not sure how, but i didnt have splash shield. WIll be adding one. Upgrading to itr pistons,cams. i will be replacing cam seals,valve gasket. New oem hg. Car will be ready Friday and dyno tuned with dyno chart for those who make offer i cant refused. Im selling because i want considering buying newer car.
Engine :
obd2 1997 usdm gsr motor have receipt for motor (legit)
Motor has around 40k miles before the rebuilt
Ngk spark plugs wires and new spark plugs
Blox Intake Mani
Aem short ram intake
obd 1 p72 ecu chipped dyno tuned with Crome pro Made 143 whp have dyno sheet
Will include stock obd2a ecu and stock gsr intake mani for those who want to bar the hb. Car will be dyno tuned again on Friday with itr cams/pistons will provide dyno
Additional parts installed on Friday
Itr pistons with brand new Piston rings set
Itr Rods
New Oem Bearings set
New Oem Headgasket
New Oem seals/cam seals/valve cov gasket/valve job
GSr head machined at the machine shop. Cleaned/Inspected Valves look good
Brand new valve seals. Head was not getting enough pressure, fixed to normal specs by machine shop.
Pro street intake mani spacer
Stock header
Act extreme duty cluth with street disc
Tranny shifts perfect no pop ups or grinds
Pro street 8.58 ilb flywhell
New timing belt/tensioner/spring/Water pum
New battery
Jdm valve cover
New oem headgasket/cam seals with distributor
Brand new obd2 distributor from rywire.com
Suspension
Nex Gt fullcoilover kit with upper pillowball mounts
Integra type r sway bar
Upgrade sway bar end links
Interior
Momo steerin wheel/momo hub no horn
Del sol seats with red stripes excellent condition
00 si gauge cluster
Blox shifter know with real jdm ctr shift boot kit
Full interior
Broadway mirror
New python viper pager alarm with keyless entry with receipt from Circuit City,warranty
New tint limo tint back windows and 50% fronts from reputable tint shop with lifetime warrant, have receipt
Exterior
Real jdm ctr lip
Cf spoon duckbill
15x6 Rota slips gunmetal with federal lotsof meat left
Brand new dot approved jdm black housing headlights, not installed yet
99-00 tail lights
I want offers only no lowballing, clean title body no accidents, Car is currently registered and smogged till Nov 2007. This is testing waters only, since i may decide to keep car after is out of shop. WIll provide dyno sheets
Looking for $7k cash only range highest offer wont be refused. I spent lot more money just for rebuild
Modified by PnoyEj6 at 1:47 PM 12/4/2006
Modified by PnoyEj6 at 2:11 PM 12/4/2006
Modified by PnoyEj6 at 6:18 AM 12/5/2006
Modified by PnoyEj6 at 4:55 PM 12/5/2006
Modified by PnoyEj6 at 6:19 PM 12/5/2006
Modified by PnoyEj6 at 7:07 PM 12/5/2006
Modified by PnoyEj6 at 12:22 PM 12/6/2006
Modified by PnoyEj6 at 4:20 PM 12/6/2006
Modified by PnoyEj6 at 2:17 PM 12/12/2006
Engine :
Blox Intake Mani
Itr Rods
New Oem Headgasket
Stock header
New battery
Jdm valve cover
Suspension
Interior
00 si gauge cluster
Full interior
Broadway mirror
Exterior
Real jdm ctr lip
Cf spoon duckbill
99-00 tail lights
Will sell for $6500 cash as is if you buy on Friday. Clean title in hand. I purchase the car for 6k. Since then i put 500 hundred dollar alarm and 200 tint job. Jdm headlights, cf duckbill, and added itr cams/itr pistons/brand new eagle h beam rods. All gaskets/seals replaced. WIll include original receipts and dyno sheet and compression check included to show motor is healthy.
Will raise price after Friday.
i have buyer for the shell. anyone wanna buy full gsr swap 97 usdm with rebuilt itr pistons, rings, itr cams, new eagle beam rods. for $3500 full swap will come with obd 1 p72 chipped ecu and obd2a p72. WIll bolt in 96-00 ek hatch perfectly. Mounts are new stock ones
engine is not bar'd. Between 35-40k original miles. You can easily barred but i dont have time to . Just need to fix secondary o2 sensor. I still have stock obd2 a p72 ecu and stock gsr manifold, if you wanna bar.
I have buyer for shell, anyone wanna buy built gsr motor with itr internals??with tranny $3500 picked up??
Gunmetal 15 inch slips $500 picked up mint del solt seats $350 with ek rails
I rather sell whole car for $6200 cash smogged and ready to transfer by this week. I will provide compression test for the built motor
2500 cash for shell
3500 cash for full motor swap
6500 cash for the whole car firm. I bought the car for 6k last month without the additional parts/alarm/tint/headgasket, etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyEj6 »</TD></TR><TR><TD CLASS="quote">2500 cash for shell
6500 cash for the whole car firm. I bought the car for 6k last month without the additional parts/alarm/tint/headgasket, etc</TD></TR></TABLE>
what if you bought the shell and the gsr motor? would you sell it for 6000 and not remove the motor. You get the seats, rims and suspension with the shell right?
