resleeving my block
who makes good sleeves for hondas? also im goin to use itr pistons that are .25mm oversize which means i would have to get sleeves that are .25mm oversize also right?
you do not need sleeves for a .25mm overbore, the stock sleeves with work just fine all the way up to 82mm of boring for all motor
the only real reason to sleeve is if you are going for a High horsepower boost setup, or if you are going to be running 82mm+ sized pistons for a high compression all motor setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">you do not need sleeves for a .25mm overbore, the stock sleeves with work just fine all the way up to 82mm of boring for all motor
the only real reason to sleeve is if you are going for a High horsepower boost setup, or if you are going to be running 82mm+ sized pistons for a high compression all motor setup</TD></TR></TABLE>
+1 you can have the stock sleeves bored over .25mm to match the pistons.
but to answer part of the original question, most sleeving compaines use the same type of sleeves, just different designs. golden eagle, bensons, rs machine, darton, all good stuff. what's most important is the install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood »</TD></TR><TR><TD CLASS="quote">
none tech-related but damn.. who that chick on your avatar
h22apwrd95
Nov 10, 2007 10:30 PM
NXAccordTO4B
Jul 19, 2003 08:27 PM
CRVRX
May 27, 2003 07:08 PM
