VTEC Light. (Noob question)
Old Dec 1, 2006 | 03:54 PM
The-Kid's Avatar
Default VTEC Light. (Noob question)
Sup guys. I'm just wondering, is there anyways that you could build like a simple light to tell you if Vtec is on? Cuz, you can't hear it that well on a SOHC at least. This is so noobish but IDK...
Old Dec 1, 2006 | 04:06 PM
unknown0001's Avatar
Default Re: VTEC Light. (The-Kid)
no there is no vtec light unless you put one manually in.
search....
https://honda-tech.com/zerosearch
Old Dec 1, 2006 | 07:25 PM
UncleD's Avatar
Default Re: VTEC Light. (Mr.RHTuner)
Are you serious?
Old Dec 1, 2006 | 07:29 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">no there is no vtec light unless you put one manually in.
search....
https://honda-tech.com/zerosearch</TD></TR></TABLE>
He knows theres no VTEC light man, he's asking if he can build one. READ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Kid &raquo;</TD></TR><TR><TD CLASS="quote"> I'm just wondering, is there anyways that you could build like a simple light to tell you if Vtec is on? </TD></TR></TABLE>
Yes you can. Just get a little LED from radioshack and tee of your VTEC solenoid wire, that way it only gets 12v when your solenoid is powered, and the light will come on.
Old Dec 2, 2006 | 10:37 AM
awang's Avatar
Default Re: VTEC Light. (Combustion Contraption)
both are DIYs
enojy
http://www.7thgencivic.com/for...55263
http://www.hondacivicforum.com/m_248922/tm.htm
Old Dec 2, 2006 | 11:01 AM
cjames235's Avatar
Default Re: VTEC Light. (awang)
i remember back in the day i put a little green led in the cluster of my old civic that thing used to be soooo tight
Old Jan 1, 2007 | 03:35 PM
Metal Head's Avatar
Default Re: VTEC Light. (cjames235)
So you want to Tee into the vtec wire? The one DIYS says something about grounding the wire.
What kinda led do we need to buy?
Old Jan 1, 2007 | 07:38 PM
Flip.'s Avatar
Default Re: VTEC Light. (Metal Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Head &raquo;</TD></TR><TR><TD CLASS="quote">So you want to Tee into the vtec wire? The one DIYS says something about grounding the wire.
What kinda led do we need to buy? </TD></TR></TABLE>
If you do this, you realize you will have to change your avatar.
And yes you need to ground the neg.(-) side of the LED. When you buy the LED it should have one long and one short side. IIRC the short sied is the neg.
Old Jan 1, 2007 | 08:06 PM
Metal Head's Avatar
Default Re: VTEC Light. (Flip01)
LMAO, No not for me.
Old Jan 2, 2007 | 02:27 AM
B18CivicEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Head &raquo;</TD></TR><TR><TD CLASS="quote">LMAO, No not for me. </TD></TR></TABLE>
lol...all ov a sudden....
Old Jan 2, 2007 | 05:02 AM
outtacontrolsol's Avatar
Default Re: VTEC Light. (B18CivicEg)
Man, this is freaky! I just replaced my gauge cluster with a JDM one , and when I swapped over the face plate, I had a hole left over where the dimmer switch used to be and I had this bright idea too. Never thought it would get randomly posted and save me the effort of asking around. Thanks guys! Appreciate the good luck and great supply of knowledge!
Old Jan 2, 2007 | 07:24 AM
cjames235's Avatar
Default Re: VTEC Light. (outtacontrolsol)
this is the one i used a long time ago........ they have orange and red also even has red and black wires so you know which is which..... just ground the black wire and the red wire gets t-tapped into the vtec wire..... easy as pie..... and just mount the led somewhere i just drilled a hole in my cluster and put it in there
<U>http://www.radioshack.com/product/index.jsp?productId=2062569&cp=&origkw=led&kw=led& parentPage=search</U>
PS..... this was back when i was 17 and did this....... and yes i did think it was cool.... would i do it now? lol no....... gay
Old Jan 2, 2007 | 11:03 AM
LSVTEC 91 Civic's Avatar
Banned
What does this have to do with all motor?
jdmwannabe3
25
Apr 14, 2006 08:57 PM
GTEC913
Mar 11, 2006 03:46 AM
GTA
11
Aug 25, 2004 11:03 PM
98mugenferio
Aug 12, 2004 12:44 PM
rebohn
18
Feb 29, 2004 05:56 PM
