do h23 rods fit h22 pistons?
Old Dec 1, 2006 | 03:16 PM
tmrtwo's Avatar
Default do h23 rods fit h22 pistons?
Do h23 rods fit h22 type s pistons without any modifications?
Old Dec 1, 2006 | 03:20 PM
nonvteclude's Avatar
Default Re: do h23 rods fit h22 pistons? (tmrtwo)
no, i believe you have to modify it to a floating wrist pin
Old Dec 1, 2006 | 03:45 PM
tmrtwo's Avatar
Default Re: do h23 rods fit h22 pistons? (nonvteclude)
what parts do i need to do that ....and where can i take that to get it done a machine shop....or is it easy enough to do myself
Old Dec 1, 2006 | 03:49 PM
Rosko's Avatar
take them to a shop, you can leave them press fit, but they will need to be honed out a bit. they will have slightly too much press fit the way they are now.
option 2 is to have them bushed and then you can have a floating pin.
Old Dec 1, 2006 | 04:29 PM
Penny's Avatar
will there be a clearance issue with the head since the h23 rods are longer?
what engine is it going in?
Old Dec 1, 2006 | 06:35 PM
tmrtwo's Avatar
Default Re: (Penny)
its the h23 block with the h22 head......using h23 rods and h22 type s pistons.......i thought the h23 rods are shorter than the h22 rods just the h23 crank has a longer stroke right?
Old Dec 1, 2006 | 06:54 PM
Rosko's Avatar
Default Re: (tmrtwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmrtwo &raquo;</TD></TR><TR><TD CLASS="quote">its the h23 block with the h22 head......using h23 rods and h22 type s pistons.......i thought the h23 rods are shorter than the h22 rods just the h23 crank has a longer stroke right?</TD></TR></TABLE>
yes h23 rods are shorter.
5.572 H23 rod
5.636 H22 rod
Old Dec 1, 2006 | 08:07 PM
bluedlude's Avatar
if you use the H22 pistons with a stock H23 crank and rods, they are going to be sticking out of the block by .018
Old Dec 1, 2006 | 11:54 PM
AssItch's Avatar
Default Re: do h23 rods fit h22 pistons? (Rosko)
so you can have the rod machined to have a press fit? no problem to the type s piston?
how much would they need to be honed out?
is there any difference on the piston between floating pin en pressed pin?
thnx
Old Dec 2, 2006 | 08:52 AM
Rosko's Avatar
Default Re: do h23 rods fit h22 pistons? (AssItch)
from what I understand the pin in a type-s piston is about .001" bigger than the regular h22 pistons. i think some people have left it alone, but imo thats a little too much press fit.
type-s pistons aslo only take type-s pins.
Old Dec 2, 2006 | 09:14 AM
AssItch's Avatar
so no prob with the type s piston if i have a type s pin pressed fitted...?
krayzieboi213
Jul 7, 2008 07:35 PM
boostedh22lude1
Oct 16, 2007 01:22 PM
jdm knight
Mar 29, 2006 06:43 AM
