question about b18c
The JDM B18C doesn't have LSD... its the transmission it's attached to that may or may not have LSD. If you're going with the B18C ITR, then yes, the transmission comes with LSD. The B18C GSR transmission has LSD as an option.
Pretty sure they came as an option.
If you want to check if you do, remove both axles and look through the halfshaft and see if theres a rod or if its free/open.
Nothing there/free/open = LSD
Rod = not LSD.
Rod = not LSD.
