Weird noise in reverse!! What the
Old May 9, 2002 | 08:47 PM
AcCoRd_HyBrId's Avatar
Default Weird noise in reverse!! What the
Its like a sqealing noise. It only does it in reverse and seems to be coming from the drivers side. Anyone have an idea of what the problem might be? Its an auto if that helps.
Old May 9, 2002 | 08:54 PM
Accord94DX's Avatar
Default Re: Weird noise in reverse!! What the (AcCoRd_HyBrId)
normal.
Old May 9, 2002 | 08:57 PM
Default Re: Weird noise in reverse!! What the (Accord94DX)
If its normal then why has it never done it before. I bought the car with 16,000 miles on it , it now has 70,000 and it just recently started doin that
Old May 9, 2002 | 09:07 PM
Accord94DX's Avatar
normal. hear it all the time.
Old May 9, 2002 | 09:11 PM
Kazmans94cord's Avatar
as do i my son
Old May 10, 2002 | 07:53 AM
Razor's Avatar
if you have a manual tranny, the car will make a high pitched 'whining' noise when you go pretty fast in reverse, like over 5mph or somethign.
its normal.
Old May 10, 2002 | 07:56 AM
CmptchAV6's Avatar
Default Re: Weird noise in reverse!! What the (Razor)
he has an auto and I dont think it is normal. I have never heard an auto doing that before.
Old May 10, 2002 | 07:58 AM
4doorH22's Avatar
Does it make the noise when you're sitting still in R, or only when you're moving? Does it's pitch change with speed?
Old May 10, 2002 | 08:07 AM
SOHCArchangel's Avatar
Default Re: Weird noise in reverse!! What the (4doorH22)
check your rear brake pads, the squeal or "dumbass, change me sensor' is going into effect
Old May 10, 2002 | 08:09 AM
John's Avatar
New User
Default Re: Weird noise in reverse!! What the (SOHCArchangel)
could be a wheel bearing too... or maybe the Arospeed BOV flexing it's mAd sKiLlZ in reverse y0! (j/k)
Old May 10, 2002 | 08:37 AM
Gennady's Avatar
New User
Its your Veetechk engaging in reverse.
[Modified by Wont be beat, 12:37 PM 5/10/2002]
Old May 10, 2002 | 09:07 AM
It does not do this when sitting still only when moving and its not the whining noise you all are talking about it does that to and that is normal but this sounds more like a metal to metal sqealing noise, What do you all think? Brake pads were just changed .
Old May 10, 2002 | 09:25 AM
John's Avatar
New User
Probably your wheel bearings.
Old May 10, 2002 | 09:27 AM
Default Re: Weird noise in reverse!! What the (DunReit)
Ill check that, thanks you think they just need to be repacked or what?
Old May 10, 2002 | 09:32 AM
John's Avatar
New User
Replace them... front ones are around $40 a piece, rear ones are around $70. What kind of car do you have? You can order the bearings at http://www.hondaautomotiveparts.com
Old May 10, 2002 | 09:37 AM
[QUOTE]Replace them... front ones are around $40 a piece, rear ones are around $70. What kind of car do you have? You can order the bearings at [QUOTE]
97 Accord SE
elteejee
Honda Insight & CR-Z Hybrid
Jan 17, 2018 12:26 PM
KaoSyN
May 17, 2005 11:21 PM
civilEX98
Jan 23, 2005 09:15 AM
