wisconsin DECEMBER 2006 (FS,WTB,TRADE)
well i use to run this ish a while ago and since i got my computer running again i'm taking over the forsale threads to save the confusion. plus to stop the several monthly threads from poping up
FS-
'95 Gsr rear disc brake conversion. Comes with everything to do the conversion except.... You will need brake lines, and you will need to replace the rear control arm bushings. Taking reasonable offers.
Front + rear struts with H&R springs removed from 95 Gsr. $100 complete set with forks.
Rota Jmag rims... bought 1 month ago, have original boxes etc for them. Paid $550 without tires, taking best offer. Not 1 scratch on them!
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
Hasport Mounts for 88-91 Civic/Crx with Hydro tranny. Complete kit, come with bolts (not pictured) 80A bushings-$399
Rear T bracket for 88-91 Civic/Crx for use with Hydro b-series tranny-$30
BUILT '92 Jdm B16 head. Rebuilt less then 1500miles ago by Mike at extreme parts. Has Supertech valve springs/titanium retainers, ferrea stainless valves, new Oem Honda valve seals, type r LMA's. Intake ports were ported/polished by DH-racing. Before head was built it was hot-tanked/resurfaced by C&S machining. Comes with valve cover/all the cam caps/bolts etc. Vtec solenoid. I will include stock b16 intake manifold/injectors/fuel rail. All you will need are some cams. -$900
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
CNC Reverse throw clutch pedal with master cylinder- For all you guys that want to convert your car to true hydrolic this is what you need. All you do is just run your -3an line straight to your clutch slave cylinder-$70
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $450
Edelbrock Victor X Intake manifold for b16/type r heads. Installed it and car sat ever since. Basically brand new, have box as well.-$270
Modified Avid racing traction bar for 88-91 Civic/Crx's. This is what all you turbo guys need if your 3" or even 4" downpipe hits the traction bar. Has mad clearance.$200 + your stock one.
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
RARE '91 LSD Y1 cable JDM tranny. NO grinds. picture of tranny before i installed it on my ef8. '92 JDM b16a engine is also for sale. Bone stock has 65K on it!! Runs great, doesn't burn any oil etc. Come check it out before you buy! I'm looking to sell the complete swap OR i'm willing to part out and sell everything seperately such as the tranny, complete b16 head or block. Throw me some offers or pm me if interested.
Rear SPC toe link adjusting kit for 89-91 crx,92-97 del sol,88-00 Civic, and 90-01 integra's. Like new, can't even tell it was used. Perfect working condition-$80
88 RHD crx rolling shell. All you need is a motor/tranny. $2500 $2300 loweredclean registered title. pm me for further details.
Intake system removed from 91 Ef8 Sir crx-$100!
Front upper strut bar. rear lower was sold. Universal fit, 88-00 civic 90-01 integra's- $10 each picked up.
Cable b-series halfshaft removed from 91 JDM b16 engine-$40
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something
-$25
obd0-obd1 B-series alternator-$35 picked up
obd1-obd2 ignition coil-$15
obd1-obd2 ignitors-$5 each
big yellow wastegate spring for tial 44mm wastegate (7 psi)-$15
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
Steering column w/ tilt option for 88-91 Civic/Crx-$30
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
95 Gsr power steering pump-$20
95 Gsr power steering pump brackets-$15
95 Gsr alternator brackets (top+bottom)-$10
95 Gsr Honda water pump-$15
95 Gsr Honda timing belt, like new only 10k miles on it-$10
95 Gsr upper/lower alternator brackets-$15
95 Gsr power steering brackets (have an extra 2 but they are just the lower ones)-$5 each
95 Gsr cam gears-$10
92-95 Civic front strut forks-$10
92-95 Civic steering column yoke-$1
94+ Integra drivers side motor mount bracket-$10
90-93 Integra front wheel hubs-$15
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
I believe this is a 92-95 Civic power steering rack+pinion-$20! Price LOWERED!! $10 please come pick this up!
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
88-91 Civic/Crx rear upper control arms. Great condition, no rust. bushing in great condition-$15 for both sides Price LOWERED $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
obx pedal pads, missing 2 nuts and 1 clamp which you can get at a hardware store-$2
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
88-91 Civic/Crx fan
94+teg fan
90-93 Teg fan
10" slim fan
92-00 Civic fan
$20 Each! Lowered price $15 each
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Anyone interested in any parts PM me
Modified by theinfamouskonrad at 11:14 PM 12/3/2006
-$25
P72 stock rods $10
88-91 Civic/Crx fan
94+teg fan
90-93 Teg fan
10" slim fan
92-00 Civic fan
Windows-
$35 each!
2004-up Honda S2000 Oem front lip color sebring silver...$200.00 almost new
2004-up Honda S2000 Service Manual $50..firm coz they are almost new
WORKWHEELS VsTx 18x8 front +58 and 18x10 rears +58...asking $2800 and they are brand spankin new with all the plastic cover and box...
WTB: 96-up Civic Lx manual trans for Sohc...no grind or pop out pls!!!
96-up Civic Lx 4dr front bumper...prefer silver but any color is ok too
96-up Civic Lx 4dr driver side mirror...prefer silver but any color is ok
96-up Civic Lx 4dr driver fender...prefer silver but any color ok too
Pls pm me with anything u have or would like to buy from my S2000 stuff...thanks much
Used Nitrous kit. This kit is a N.O.S. kit, it has the older style solenoids which i think are better then the new ones. It has a blue ten lbs bottle that is still half full. It currently has 100 shot jets in it right now. I guess jet kits are real cheap anyways. The system works perfect.
. I'm selling it cuz i have no use for it any more. I'm asking $250. If interested call Nick at: 262-352-5459. Thanks
For Sale:
#1. 96-00 Civic EX Coupe front sway bar, includes D brackets and endlinks (not all pictured) $40
#2. 94-01 Integra Rear Sway bar, complete with endlinks $40 (since painted black as seen in 2nd pic)
lets get some picsand more info on your integra. thenmaybe it will sll easier. i know a guy who is looking for a older teggy. hit me up with all the info you can as well as lots of pics and a accurate discription too.
i need a non leaky non beat the expletive up 88-91 civic/crx radiator asap. meaning this ******* weekend. mine took a **** and its dripping from the bottum of the runners
WTB b16 head
b-series Header
b-series short or long block
EG CF tailgate
4 sale
tial 38mm wastegate make offer
T3/T4 turbo like new make offer
ss auto crome b-series manifold make offer
charge piping for EF make offer
Jonny RR intercooler make offer
450 DSM injectors make offer
greddy BOV make offer
or can make me an offer for all turbo kit
or will trade for B16 head and NA stuff
b16 cams 70 obo
b16 valve cover 50 obo
p2p ecu 50 obo
99 si P2T ecu 60 obo
2 EG clocks 20 obo
eg cluster 50 obo
94-00 passager teg b-series axle 50 obo
94-00 teg b-series axle used 25 obo
92-95 civic SOHC axles pair used 40 OBO
DC cargo cover leather black make offer
OBD 0 b16 intake manifold 40 obo
b16 bar block with golden eagle block gaurd 70 obo
EG headlights 50 for both
frost white tailgate 40 obo good condis.
EF clutch cable 10
2 EG cluster cover 15
EG taillights inner 15
b-series throttle bodie 30 obo
99 SI hood si blue 70 obo
GSR cam caps with rails 25 obo
B16 cam caps and rails make offer
B16 crank make offer
integ tail lights make offer
EG frost white rear bumper make offer
2 black 14" wheels five spoke very light look like slips good for slicks make offer
stock eg radios make offer
40 watt MTX amp make offer
obd2 gsr alternater make offer
obd1 sohc alternater make offer
"I can get pics just ask "
b-series Header
EG CF tailgate
4 sale
b16 cams 70 obo
p2p ecu 50 obo
2 EG clocks 20 obo
eg cluster 50 obo
EF clutch cable 10
750 or 600 and bring your steelies
Want to sell as whole but can possibly part out some of it I KNOW PICS HELP BUT 4 THE PRICE i shouldnt have a problem car sits at my work and doesnt get driven
91 crx black SI
BODY - rust on 1 of the quarter panals(already cut out and welded patch panal)
there is some rust under the sides on the rockers and on the doors. I was planning to fix the quarters and the bodykit would cover the rest and if the rust made it past the door panal it would be time for new doors
wINGS west/Mugen replica 6pc bodykit (NEW) NOT INSTALLED i have factory bumpers too!
used hood
used hatch (dx no wiper blade and tinted) hood and hatch are white
2 New fenders
SUSPENSION AND BRAKES
H&R SPort springs - new in box
MOOG tie rod ends not installed
Brembo cross drilled and slotted rotors front and back (0miles but are installed)
brand new installed rear hub assemblies (wheel bearings)
2 brand new calipes installed 0 miles
brakes bled
needs axels - i will include 2 for a 92-95
exhaust is oem replacement (duel tips) VERY GOOD CONDITION CAT BACK
brand new battery
no name strut bar
new used dizzy
INTERIOR
MINT BLACK and red seats si
interior is a 8-10 id say
sony cd player barely works if at all
short throw - not installed
momo hub - not installed
valve noise but runs fine
zc block
si head
si trans
oem 91 si blades black with silver lip and new fuzion HRi uni-T tires (0 miles)
750 or 600 bring ur steelies
car is in waukesha call me at 414 803 6522
91 crx black SI
used hood
2 New fenders
brakes bled
brand new battery
no name strut bar
new used dizzy
INTERIOR
zc block
si head
si trans
Up for sale is a my 94 ex hatch shell. has no interior except the dash. the radiator support is gone. the hood is gone. the trans mission is inside it. the fenders are inside of it as well as the headlights. it has a sunroof and rear disc brakes. it is black. the only rust is ont the rear quarters and the tailgate. Make me reasonable offers. if i get good enough pffers i will throw in all my spare parts as well. trying to clean up the garage and put some cash together to finish my project... so on to the pics.
Looking for misc eg interior in black. willing to trade this or any of my moutain of d series ****. Also have a list of stuff on my f/s thread.
Modified by Tink2150 at 10:25 PM 12/10/2006
Modified by Tink2150 at 7:07 PM 12/13/2006
