window off track? 2000 em1
Old Dec 1, 2006 | 12:25 PM
killaj12's Avatar
Default window off track? 2000 em1
sup guys
my driver side window is messed up
i slammed the door while the window was rolled down a while back ..
now when i try to roll the window up, it moves up and forward too
additionally, its rolling up on the outside of the rubber track, which is ripping up the rubber pretty bad
is this something i could fix myself ? the motor seems fine ..
i plan on taking apart the inside door panel today or tomorrow ..
do i have to remove any other panels ? and if it is off track, do i have to buy new parts ?
or is it something i could just set back on track ?
Old Dec 1, 2006 | 12:29 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: window off track? 2000 em1 (killaj12)
it could be a few things, you will need to pull the door panel to check. i had the same problem, but i was lucky, and i was able to glue a window that broke on me last week. you may need a regulator though. tough to tell unless you pull it apart.
Old Dec 1, 2006 | 12:32 PM
killaj12's Avatar
i can check just by taking out the inside door panel ?
Old Dec 1, 2006 | 12:36 PM
Rodney's Avatar
Default Re: (killaj12)
corect, that is how you access the window components.
Old Dec 1, 2006 | 01:01 PM
killaj12's Avatar
thanks for the info ..
just another quick question..
so its most likely either a broken window or a messed up regulator?
theres no way it just jumped off the track ?
Old Dec 1, 2006 | 01:03 PM
Bense's Avatar
It used to happen to me ALL the time.
you're going to have to keep a phillips head and a 10mm socket + rachet in your door pocket.
I bet it got off track.
Old Dec 1, 2006 | 01:11 PM
killaj12's Avatar
Default Re: (Bense)
if it just got off track, how would i go about putting it back on track ?
is it a simple process ?
i'd like to know before i actually take the door panel off
so that i would know what to do when i fix it
btw, thanks for all the helpful info
Old Dec 1, 2006 | 02:39 PM
SFBPI504's Avatar
Its super simple you just take the door panel off and I had to take out my speaker and behind the speaker where the track is there a bolt loosen it and put the window back in between the track to where its suppose to be. Hope this helps.
Old Dec 1, 2006 | 03:03 PM
killaj12's Avatar
great, thanks for the info guys
hopefully i can get this settled tonight or tomorrow
i appreciate the help
Old Dec 1, 2006 | 03:09 PM
OMG naD16 lol's Avatar
sprayed my window channel with silicone spray after it popped off 5 time one winter.... hasnt come off since, just make sure to lube it up every once in a while
Old Dec 2, 2006 | 08:07 AM
8krdline's Avatar
Default Re: (OMG naD16 lol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG naD16 lol &raquo;</TD></TR><TR><TD CLASS="quote">sprayed my window channel with silicone spray after it popped off 5 time one winter.... </TD></TR></TABLE>
Made my windows go up faster too
Old Dec 2, 2006 | 11:17 AM
killaj12's Avatar
fixed
thanks for all the help guys
Old Dec 2, 2006 | 02:26 PM
Rodney's Avatar
bah, you jinxed me..... my 99 si driver's side window did the same thing a few hours ago... anywhom, glad you got it together
Old Dec 2, 2006 | 03:27 PM
hphp80620's Avatar
There is a RECALL from hoinda on this 99-00 Civic two doors..and a repair kit.
Old Dec 2, 2006 | 05:11 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (hphp80620)
there is no recall from honda.. its a service bulletin.. and if its out of warrenty they prob wont fix for free. and all u need to do is pull ur run channel and clean the **** out of it and the lube it up.. they get dirty and stuff and cause's problems
Old Dec 2, 2006 | 05:33 PM
Rodney's Avatar
Default Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">there is no recall from honda.. its a service bulletin.. and if its out of warrenty they prob wont fix for free.</TD></TR></TABLE>
my 99 si has 200k on it... WAY out of warranty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">and all u need to do is pull ur run channel and clean the **** out of it and the lube it up.. they get dirty and stuff and cause's problems</TD></TR></TABLE>
lol, that is exactly what i did.
Old Dec 2, 2006 | 05:40 PM
hphp80620's Avatar
Default Re: (Rodney)
did it too, it worked until it got cold...then it popped out of the from rail again..it's too flexible and moves when the window goes down.. and yes it was a bulliten and they did fix if for free after some persist complaint but that was one year after it was bought new...I saw the TSB online right after that..
MovinDave
Jan 16, 2012 12:52 PM
Lightsped
Aug 28, 2008 11:14 AM
smooz EK
11
Dec 5, 2006 12:08 PM
hott-nix
Apr 3, 2005 04:04 PM
Senbonzakura
Mar 27, 2003 09:31 PM
