motor troubles need help
Old Dec 1, 2006 | 11:05 AM
fastintegra's Avatar
Default motor troubles need help
ok my car is a 92 gsr,im runnin the b17 blocc with a b16 head.the blocc has wiseco high comp pistons...my problem is it started blowin smoke a few weeks ago...i thaught maybe it was the pistons and rings were shot cuz it was over heatin alot...i had Rob the admin on b20vtec.com(sum of you might know him) do a leak down test and the results were that the rings were fine.he said there actually sealin up really good...so now i need to figure out why its blowin smoke..also when the car is runnin if i take the oil cap off it blows air out...i forgot totell rob bout that...it blows smoke only when i get on it hard or rev it up...anybody got any ideas wat it could be...im thinkin maybe its a exhaust valve seal,wich would explain the air comin out of the oil cap and alsoif it was bad it would let oil in and burn out in the exhaust wich would explain the smoke...am i right?or could it be suttin else...any help would appreciated....thanks
Old Dec 1, 2006 | 12:58 PM
Default Re: motor troubles need help (fastintegra)
bump bump
Old Dec 1, 2006 | 10:07 PM
anybody got any info?
xlasianizelx
Aug 5, 2008 07:37 PM
924doorEG
31
Jan 8, 2008 12:25 AM
jdmintegralsvtec
Sep 7, 2006 04:09 PM
Dohcvtec59
Aug 11, 2004 08:13 AM
VTEC-DA
Mar 15, 2003 08:02 PM
