Car won't warm up/heat. Long..
Old Dec 1, 2006 | 11:02 AM
invisible's Avatar
Default Car won't warm up/heat. Long..
yes I know there's already thread similar to this but I also have a different problem also.
Before the cold weather... At first the car would idle real low and get really close to dieing and seemed to overheat by the temp gauge. Then I turned up the idle and it idles perfect now when at a stop and doesn't overheat but when ever I put it in neutral it'll go down then come back up to around 1500 then drop to 800rpm-even at normal car temp. Also when I turn on the heater, the temp drops a lot.
Ok now the cold weather...the car takes forever to warm and doesn't warm up fully even after driving. And still having the same heater problem where the temp will drop a lot.
Old Dec 1, 2006 | 11:06 AM
chrisw85's Avatar
in addition to replacing the thermostat i'd replace the temp sender.
Old Dec 1, 2006 | 12:35 PM
Slopoke's Avatar
Check your coolant level.
Check your thermostat.
nicknack25
Feb 13, 2012 09:27 PM
GSR-T-
May 29, 2009 06:46 PM
dc4drewH
Aug 31, 2005 02:00 PM
homeskillet
Dec 24, 2004 09:22 PM
confucius
Oct 23, 2002 02:46 PM
