need help B16a
hey guys I need help on locating the Knock sensor and the oil pressure switch. I'm running and Sir motor with a B16a2 intake manifold. Also need help with the hoses on the intake manifold....thanks
ok the oil pressure switch is right underneth the vtec solinoid its plug is green u cant miss it. One wire goes to the ecu and one u just ground. The knock sensor is under the intake manifold its between the 2 middler runners i believe , its also green.
i am also using an sir 2 manifold on my 1st gen b16. its easy
on the throttle body youll see two male terminal type things , run vacuums from onf of them to the pcv and the other to the map sensor.
raverx3m
Engine Management and Tuning
Apr 12, 2014 10:47 AM
94EJ1Coupe
Mar 6, 2008 11:20 PM
89sib16
11
Dec 27, 2003 01:35 AM
