duel pump takes awhile to prime, CEL stays on till it primes???
The issue is that the car is does not prime the fuel pump when I initially switch to on, but it will not prime the fuel pump and the CEL will stay on until the pump primes which can take upto 10minutes. I have had this problem for about a year, but not to this degree, usually about 30-45 seconds. It has been progressively getting worse. I finally got fed up and took the MAIn Relay out and re soldered all the joint, but still the same issue. I then took the Main Relay out of my GSR (which I know is good) and same issue. I am stumped. need some help please. THis issue is getting really annoying.
Modified by drintegra at 11:43 AM 12/1/2006
ssl2k
12
Jun 22, 2005 02:23 PM
Aphrodavid
Feb 17, 2005 12:05 PM
