MPH vs. 24.5" slicks vs. GSR trans vs. RPM
Old Dec 1, 2006 | 06:15 AM
ykracing's Avatar
Default MPH vs. 24.5" slicks vs. GSR trans vs. RPM
Guys,
I was curious what MPH people were hitting on 24.5" slicks with a GSR tranny, and at what RPM they are at when they hit the finish line...
The reason I am asking, is that I used to run 26" slicks, and my MPH was 147, and I was pretty much at the top of 4th when I cross the finish line. But I am re-doing the car to be more like a SPFWD car. So I plan to run 24.5" slicks this year. Now, I know that with my new setup, I dont expect to hit 147MPH, but I am a bit concerned about where in the RPM range I will be if I am trapping maybe high 130's low 140's on a GSR tranny. (I REALLY dont want to have to shift into 5th)
Anybody have some insite into this?
Old Dec 1, 2006 | 06:55 AM
Innes's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (ykracing)
we run the 24.5 slicks with GSR gearing
on our 155-157 mph passes we are going through the traps at 9500 rpm in 4th gear or so if i remember correctly from the datalogs
Old Dec 1, 2006 | 07:10 AM
underpressure02's Avatar
there is a gear speed calcualtor that you can enter your slick size and rev limit and it will tell you what the top speed is at the rev limit. I am looking for the link. I am sure dturbocivic will chime in with it shortly.
Old Dec 1, 2006 | 07:19 AM
ykracing's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (MazworxRaceSupply)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MazworxRaceSupply &raquo;</TD></TR><TR><TD CLASS="quote">we run the 24.5 slicks with GSR gearing
on our 155-157 mph passes we are going through the traps at 9500 rpm in 4th gear or so if i remember correctly from the datalogs</TD></TR></TABLE>
thats good to hear... because I really dont spin the car much past 9k... so using your numbers, I should have plenty of headroom..
thanks james...
Old Dec 1, 2006 | 07:20 AM
miller's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (underpressure02)
the gear speed calculator's will work to an extent, but arent exact. You will have to take into account for tire expansion.
Old Dec 1, 2006 | 07:22 AM
SlicksMH's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">the gear speed calculator's will work to an extent, but arent exact. You will have to take into account for tire expansion.</TD></TR></TABLE>
and wheel spin.
Old Dec 1, 2006 | 07:27 AM
Boner_Ben's Avatar
I am going 142 mph on a gsr trans with 24.5's crossing around 83-8500ish
Old Dec 1, 2006 | 07:31 AM
ykracing's Avatar
Default Re: (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I am going 142 mph on a gsr trans with 24.5's crossing around 83-8500ish</TD></TR></TABLE>
cool.. thanks, that makes me feel much better about it.
Old Dec 1, 2006 | 09:39 AM
fast2camciv's Avatar
what are you taking each gear to during the run?
Old Dec 1, 2006 | 09:52 AM
lugnuts's Avatar
Default Re: (fast2camciv)
about the calculators, also consider the trap speed is an average, the car is actually travelling a couple mph faster then the trap indicates.
Old Dec 1, 2006 | 09:55 PM
WOPCIVIC's Avatar
That's weird cause i have a GSR tranny and at 150mph i am at 9600-9700rpm. Same tire too. Could be more growth i guess?
Old Dec 2, 2006 | 06:37 AM
Adriano's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (WOPCIVIC)
25inch slicks + gsr tranny + 4th gear+ 9200rpms = 149mph on a dynojet.
That''s what my car showed when we dynoed it at the Quakerstate dyno challende at the track.
Adriano
Old Dec 2, 2006 | 06:52 AM
ALL IMPORT's Avatar
Default Re: MPH vs. 24.5" slicks vs. GSR trans vs. RPM (Adriano)
that souds corec twith 24.5 to me. cause when i was running 22s in was hitting 130 at the top of fourth at 8500. so 24.5 sould easily d 150 at 9k+ . i just got my new 24.5-9 but havent tried them yet & will be shifting at 9k now. just finishing up traction bars.
i was wondering this also so good wright up
Old Dec 2, 2006 | 10:01 AM
b18c195's Avatar
same here...
with 24.5 inch slicks
mines more like 8k
Old Dec 2, 2006 | 10:25 AM
SlicksMH's Avatar
You also have the 8.7/25-13.
John
M&H
bluedevil
Aug 11, 2005 09:11 PM
2point6
Mar 3, 2005 12:14 PM
2point6
Feb 19, 2005 07:33 PM
SiR831
Apr 8, 2004 11:55 AM
len
Oct 5, 2003 11:56 AM
