90 91 92 93 Integra GS common problems?
Old Dec 1, 2006 | 01:16 AM
aaronhume's Avatar
Default 90 91 92 93 Integra GS common problems?
alright well a search did not return many results... I am goint to look at a 92 integra gs today... it has 314k miles I think on the chasis (really high!) and approx. 50k on engine it was originally in CA then NV and then here in WA... so less chances of rust.
but where should I look for rust? and also, what are some other common issues with electronics, etc I should look for? thanks so much!
Old Dec 1, 2006 | 05:29 AM
MantisX's Avatar
Default Re: 90 91 92 93 Integra GS common problems? (aaronhume)
http://www.g2ic.com. Everything you ever wanted to know and not know about the DA9 DB1 and DB2.
MantisX
Old Dec 1, 2006 | 06:28 AM
projectTeG's Avatar
rocker panesl, rear quarters, front and rear bumper supports, and rear hatch. also gen2 integra have a front passenger side leak sometimes.
Old Dec 1, 2006 | 08:49 AM
aaronhume's Avatar
Default Re: (projectTeG)
where does it leak in from?
thanks everyone!
Old Dec 1, 2006 | 10:15 AM
projectTeG's Avatar
Default Re: (aaronhume)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume &raquo;</TD></TR><TR><TD CLASS="quote">where does it leak in from?
thanks everyone!</TD></TR></TABLE>from the cowl into the blower motor and down on to the floor pan.
Old Dec 1, 2006 | 03:25 PM
HondaPartsHero's Avatar
Technical Hero
I can only tell you from my experience on my 90 LS with 140k. The only problems I've had so far are:
- replaced both axles (popping)
- replace starter
- alternator was replaced right before I bought it
- front brakes
- front and rear motor mount replaced
Other than those mechanical issues it has a few electrical "bugs":
- Climate control lights work on and off
- Cruise control works intermittantly but does work
- Its a 4 door so the front drivers window won't go down all the way, the passenger window is slow to roll up, and the other windows can't be controlled except from the master switch
I'm not sure where mine was from but it does have the rear quarter panel "Honda" rust, and the paint on the hood and trunk lid has seen its better days but no other bad rust spots. Overall its been a very reliable car and I would keep it forever if I hadn't found an awesome deal on an Accord from a family member. Now its for sale
Old Jun 3, 2019 | 09:49 AM
Than Nstice's Avatar
i have a 1993 twin carb integra that wont produce any spark
what could be the issue.....it died instantly while driving and wont start now
Old Jun 5, 2019 | 12:08 PM
wunfstgsr's Avatar
Loved
Community Favorite
Check the ignition coil inside the distributor.
Old Jun 6, 2019 | 05:12 PM
tamboo's Avatar
10 Year Member
also check cam/crank alignment.
my coil died at about 10 mph doing a left turn.
timing belt jumped a notch and drove me nuts for a few months.
drove it quite a bit with no consequences
but ran a bit shitty and hot when warm.
fuel economy was crap too.
jriley60
Aug 7, 2008 04:17 AM
92hatch_cx-t
Suspension & Brakes
Apr 16, 2007 09:49 PM
audiimportech
Nov 15, 2005 02:28 PM
evoalf
Apr 20, 2005 07:42 PM
Savestheday21
Jul 1, 2003 10:31 PM
