project won't start
just put an ls w/b16 tranny(obd1) in my buddy's ek coupe(obd2). everything is connected and not throwing any codes. motor was taken out of running car so timing should not be an issue. we are using an automatic ecu for now and the O2 sensor is broken. motor turns over and even feels like it wants to start but it just won't. could one of those 2 be the problem or does anyone else have any idea??
still stuck, checked all grounds. checked injectors. ecu is good and everything looks fine, but it still won't start.
someone help with some advice or ideas.
well, injectors don't look like they are opening and the O2 sensor is broken. would there be any correlation. someone plz help. day three of install.
Check to see if your getting spark and if so then check to see if your getting fuel...The first 2 things i would check 02 sensor would just throw a code but it should still start. I had the same problem with mine and it was my fuel pump was bad..
honda injectors are known to freeze up after sitting a while, give them all a tap with a 6 inch extention for a 3/8 ratchet and see what happens, you should be fine with an auto ecu..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">i think the auto ecu wont work for it, i think the pins are diffrent</TD></TR></TABLE>
Exact same thing, it's only Slightly different on the inside.
Did everything hook up right, being it was an odb2 harness?
the harness was good, just a little re-wiring involved. after checking evereything again, the injectors are not firing. they are either clogged or not getting signal to open.
thanks for the tip on tapping those injectors, i hope that works.
if not, what would be wrong that wouldn't let the signal get to the injectors to open up.
i don't know if this will help me, but it gave me some good info and some ideas of things that i need to check. i figured this link will help anyone in my shoes and i thought it was a good informative read. if you want some ideas on troubleshooting your injectors check this link out.
http://auto.howstuffworks.com/...4.htm
hope this works for me.
jdmallmotorhatch
Aug 15, 2008 11:03 PM
itrhopeful
29
Jan 16, 2005 03:54 PM
