Lookin for a 93 accord dash
anyone on hte board have an extra they want to sell?? this is the secnd one of mine that has cracked. i dont know why. i think maybe my headunit is too heavy or something. i know i should put that screw on the bottom to add support, but it is way hard without removing the center console which i reallt dont want too. anyways, any help would be great. just upgraded the whole soundsystem another grand
You don't need a whole dash do you? I had the same problem with heavy headunits cracking the plastic enclosure/trim around it. Easy to fix. It should be just a double DIN plastic tray that slides out of the center consol (Should be around $30, but ugh, so makes stereo so easy to steal). Just support the underside of the head unit with some wood. I have a half-din crossover under my headunit, so basically I have a little block of wood under the crossover (resting on the chassis center tunnel) then another block of wood between the crossover and headunit. It's solid as a ****.
lookin for a black one. i have the installation kit for the head unit, and it has the tray that goes under the head unit, but that whole piece is too heavy. how did you put the wood under the setup that makes it stay there?
good idea. ill have to try that when i put in the new head unit. still lookin for an uncracked dash though. mine is the one pice that goes all the way aroung the guages too. mad gay cause i have to pull everything apart.
