Break question!!!
Old Nov 30, 2006 | 09:21 PM
JayDeeMDc2's Avatar
Default Break question!!!
Hey there my friend got and EK and he wanted rear disc break conversion from the 99-00 civic si.. what would he need from the car to get his rear disc break conversion done?? i didnt do much research on it but it would be nice if anyone could help out thanks
Old Nov 30, 2006 | 09:25 PM
BlueIntegraBoy's Avatar
Default Re: Break question!!! (JayDeeMDc2)
There's a lot of research you need to do. But to make it simple, he'll need:
1. Trailing arm with brakes
2. Ebrake cables
3. Brake lines
Old Nov 30, 2006 | 09:41 PM
JayDeeMDc2's Avatar
how hard is it to do this conversion?? and were should i begine my research??? thanks
Old Nov 30, 2006 | 09:46 PM
Search: Rear disc (disk) conversion
It's a simple bolt off and bolt on affair. Really straightfoward with a ratchet sockets.
Old Nov 30, 2006 | 09:56 PM
MidwestSiR's Avatar
you'll also want a 40/40 proportioning valve and the master cylinder from the Si as well..
Old Nov 30, 2006 | 10:07 PM
JayDeeMDc2's Avatar
what is a fair price for this conversion?or as far as rear disc conversion i heard the 94-00 integra break fit also??? would i need the same parts from an integra also??
Old Nov 30, 2006 | 10:09 PM
Eran's Avatar
HT White Ops
Default Re: (JayDeeMDc2)
150-300 depending on location, time, completeness, and condition.
Old Nov 30, 2006 | 10:10 PM
chrisw85's Avatar
99-00 Si prop valve is the same for 96-00 hatchbacks; the 99-00 Si has disc brakes.
You dont really need a bigger m/c; the fluid volume is about the same between a drum wheel cylinder and the rear disc calipers. It's when you also upgrade your front brakes you want a bigger m/c.
Old Nov 30, 2006 | 10:15 PM
JayDeeMDc2's Avatar
Old Nov 30, 2006 | 10:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDeeMDc2 &raquo;</TD></TR><TR><TD CLASS="quote">or as far as rear disc conversion i heard the 94-00 integra break fit also??? would i need the same parts from an integra also?? </TD></TR></TABLE>
Yes
Old Nov 30, 2006 | 10:22 PM
MidwestSiR's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Si prop valve is the same for 96-00 hatchbacks; the 99-00 Si has disc brakes.
You dont really need a bigger m/c; the fluid volume is about the same between a drum wheel cylinder and the rear disc calipers. It's when you also upgrade your front brakes you want a bigger m/c.</TD></TR></TABLE>
i thought that was just DX hatches....
Old Nov 30, 2006 | 10:31 PM
chrisw85's Avatar
Default Re: (MidwestSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">i thought that was just DX hatches....</TD></TR></TABLE>
46210-S04-902 VALVE ASSY., PROPORTIONING 96 cx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 96 dx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 97 cx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 97 dx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 98 cx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 98 dx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 99 cx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 99 dx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 99 Si cp
46210-S04-902 VALVE ASSY., PROPORTIONING 00 cx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 00 dx hb
46210-S04-902 VALVE ASSY., PROPORTIONING 00 si cp
thats cut and pasted from http://www.slhondaparts.com; theyre all the same prop valves
Old Nov 30, 2006 | 10:42 PM
F20Cteg's Avatar
Actually everything except the EX has the same prop valve, not just the hatchbacks.
Old Dec 1, 2006 | 07:22 AM
MidwestSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">46210-S04-902 VALVE ASSY., PROPORTIONING 96 cx hb
thats cut and pasted from http://www.slhondaparts.com; theyre all the same prop valves</TD></TR></TABLE>
nice.. you learn something new every day. Good info right there
Old Dec 1, 2006 | 07:32 AM
pdiggitydogg's Avatar
its spelled "brake"
be sure the bolts arent torqued too much, during installation of the rear toe arm...you can really screw up your life doing that
Old Dec 1, 2006 | 07:33 AM
EL Vap133's Avatar
...and that is why I stuck with my stock prop valve.
Old Dec 1, 2006 | 09:48 AM
Syndacate's Avatar
After all that **** I'm just curious if my EX (non-abs) uses something different. :-P Gonna og check part # now.
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING
Is this the same part? Sure looks it.
Old Dec 1, 2006 | 10:02 AM
chrisw85's Avatar
46210-S04-962 VALVE ASSY., PROPORTIONING 98 civic ex non-abs
its a 962 compared to the other's 902...where'd you get your # from? SR3 sounds like the older civics.
Old Dec 1, 2006 | 10:42 AM
F20Cteg's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Is this the same part? Sure looks it.</TD></TR></TABLE>
Well in your sig it says 95 Civic EX. These part numbers are for 96-00 civics.
Every 6th gen civic that came with the small rotors up from and the drums in the rear uses the same prop valve as with the big rotors up from and discs in the rear.
95dxb18b1
Aug 29, 2011 06:47 PM
Bambooseven
Sep 22, 2010 03:59 PM
rediye
May 9, 2009 11:04 AM
94eghatchcx
Sep 11, 2007 10:33 AM
