ls motor into a gsr
i have a blown gsr motor and i wanted to swap in an ls motor into my car while i rebuild my gsr. is it a direct swap or do i have to swap ecu's also?
because gsr fuel tables are different thn a ls ecu plus the added fact that the gsr ecu is a vtec ecu and teh ls a non-vtec ecu so you will have a check engine light. plus personally i think it's half assing it and here at Honda Evolution Motors Sports we try our best to not skip corners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton »</TD></TR><TR><TD CLASS="quote">i have a blown gsr motor and i wanted to swap in an ls motor into my car while i rebuild my gsr. is it a direct swap or do i have to swap ecu's also? </TD></TR></TABLE>
if you keep it under 4k rpm you should be ok. anything over 4400 will make the run rich, because that's when vtec kicks in (more air).
its only temperary so it wouldnt be half assing it cuz im mean i gotta get to work some how to make money for building the new motor. but thats besides the point. so the bottom line is that if i stay under the vtec point, it will work right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton »</TD></TR><TR><TD CLASS="quote">its only temperary so it wouldnt be half assing it cuz im mean i gotta get to work some how to make money for building the new motor. but thats besides the point. so the bottom line is that if i stay under the vtec point, it will work right.</TD></TR></TABLE>
Yea , you dont wanna hit vtec , on that LS motor , slight chance you might blow the welds on the intake manifold
I requested a short story for a title.
and the redlines are different so that computer will let that engine rev alot higher than the Ls ecu would , you might want to get a diff ECU cause even with an LS you will want to put your foot in it every now and then. Better to be safe than have 2 blown motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! »</TD></TR><TR><TD CLASS="quote">just get a LS ecu they are cheap</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stocker2shocker91 »</TD></TR><TR><TD CLASS="quote">and the redlines are different so that computer will let that engine rev alot higher than the Ls ecu would </TD></TR></TABLE>
Since he's putting in an ls motor and using a gsr ecu the gsr ecu will give him the vtec cel codes and therfore not let it rev till redline. Even if it didn't have a dual rev limiter u would hope he would be smart enough not to rev it to 8000 rpms, all about being smart and having will power.
why would i do that. i need the gsr ecu for when my gsr motor is done. im gonna see if i can pick up an ls ecu to go with the ls motor when i head over to hmotors to pick everything up.
