hey what do you guys think of this???
Old Nov 30, 2006 | 08:09 AM
ReV LiMiT's Avatar
Default hey what do you guys think of this???
http://www.importintelligence....-Edit
this is the perfect launch system from importintelligence.com. it sounds almost like two-step. is this safe since its not integrated into the ecu like aem has it? has anyone had any experience with this particular system on the strip?
Old Nov 30, 2006 | 01:38 PM
JDogg's Avatar
Default Re: hey what do you guys think of this??? (ReV LiMiT)
its nothing special... basicly just like an msd 2step w/o pills
only 10psi at 4400 rpms from an sr20.. aem 2step/antilag will make it boost whatever you want
Old Nov 30, 2006 | 05:02 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: hey what do you guys think of this??? (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">its nothing special... basicly just like an msd 2step w/o pills
only 10psi at 4400 rpms from an sr20.. aem 2step/antilag will make it boost whatever you want </TD></TR></TABLE>
matt makes a nice product, and they get lotsa props from me for the help on our s15 swap. but j-dogg is correct.
Old Nov 30, 2006 | 08:18 PM
mec. pedri's Avatar
i installed a msd 6al with a 2 step box using a 12 volt relay and stock clutch switch that did pretty much the same thing that this kit does. went down to radio shack bought an led for 3-4 dollars and it performed just as this system is described. its nicer with the system cause it appears not to use as much wires as my setup
wade
Nov 13, 2007 06:47 PM
AllMotorRandy
Mar 23, 2006 01:25 PM
lupin5
May 23, 2005 06:36 PM
b18prl
Sep 13, 2004 10:44 PM
S2KP
Jun 4, 2004 07:38 AM
