Compression?
Old Nov 30, 2006 | 07:03 AM
hitmen9342's Avatar
Default Compression?
Hey guys what is the compression from factory on an H22A? And what would be a good compression reading on a used H22A?
Old Nov 30, 2006 | 07:56 AM
TheMuffinMan's Avatar
He knows where you live!
I'm assuming you mean like a compression check in the cylinders?
For the most part higher numbers ~200 or so are best but the key thing is they are all similar like 200-205 for all cylinders
Old Nov 30, 2006 | 08:07 AM
hitmen9342's Avatar
Default Re: (TheMuffinMan)
ok mine checked out at 250 straight across I take it thats good then. I just had the oil pump rebuilt.
Old Nov 30, 2006 | 08:13 AM
yep anything above 200 is good to go so 250 across all 4 is awesome
Old Nov 30, 2006 | 12:43 PM
iam7head's Avatar
Default Re: (hitmen9342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitmen9342 &raquo;</TD></TR><TR><TD CLASS="quote">ok mine checked out at 250 straight across I take it thats good then. I just had the oil pump rebuilt.</TD></TR></TABLE>
WTF?how many crank you pull?
a brand new s2000 2.2 with 11.0 compression can only do 210-215 on 7crank
Old Nov 30, 2006 | 01:38 PM
JimBlake's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">a brand new s2000 2.2 with 11.0 compression can only do 210-215 on 7crank</TD></TR></TABLE>After the rings & cylinders have polished each other, I'd expect compression to get better.
Compression testing depends real strongly on cranking RPM. Also depends on the internal volume of the gauge itself. My '95 GSR had 230 or 235 with my gauge & everything. I'm sure it would be lower if cranked at slower RPM, or measured with a different gauge.
So it's kinda misleading to compare actual pressures without knowing these kinds of details.
Old Dec 1, 2006 | 09:07 AM
hitmen9342's Avatar
well the compression test was done after my oil pump was rebuilt and it was after 5 crank and I was present when they did the test. And the test was performed by Driven Concepts in Tampa, Florida
XstouterX
Feb 26, 2006 03:06 PM
swappedcx
Feb 25, 2006 03:52 PM
a2dadamm
Jan 6, 2006 08:20 PM
maka
Feb 23, 2004 08:27 AM
DOHCarp
Sep 11, 2003 07:10 PM
