went to the track need input on my slips
Old Nov 30, 2006 | 05:05 AM
quis84's Avatar
Default went to the track need input on my slips
went to etwon two weeks ago only got 2 runs this is the first time running the car at the track but enough excuses here are the slips the runs were on 205/50/15 bfg's
run1
60'-2.628 i launched to low and bogged bad at the line
330-6.220
1/8-8.917
mph-91.71
1000-11.210
1/4-13.132
mph-117.57
run2
60'-2.353
330-6.027
1/8-8.803
mph-90.40
1000-11.41
1/4-13.086
mph-115.81 i let off before the lights for some dumb reason hoping to do much better with some more seat time and more runs it took me over 2 hours to get these two runs
Old Nov 30, 2006 | 05:38 AM
RSX8600's Avatar
Default Re: went to the track need input on my slips (quis84)
it's all in first 60 feet... mod list??
Old Nov 30, 2006 | 05:45 AM
quis84's Avatar
stock block ls custom turbo kit in a crx si dont know exact hp only on a street tune the turbo is a 57 trim t3/t4
Old Nov 30, 2006 | 06:00 AM
RSX8600's Avatar
Default Re: (quis84)
More seat time will help and better 60ft. SLICKS heheeh
Old Nov 30, 2006 | 06:14 AM
quis84's Avatar
thanks any one else i am trying to get an ideal of the time my car is capable of with these speed and a better 60ft
Old Nov 30, 2006 | 06:28 AM
RSX8600's Avatar
If you trap between 115-120mph should see 12.5-11.999
Old Nov 30, 2006 | 07:55 AM
Kev-turboEJ1's Avatar
Default Re: (RSX8600)
seems like you're having the same problems as me. Check out my thread
https://honda-tech.com/zerothread/1824227
Old Nov 30, 2006 | 08:31 PM
choreboy's Avatar
work on your 60ft. mph is good.
Old Nov 30, 2006 | 08:37 PM
vaporboy12's Avatar
Default Re: (choreboy)
seat tim seat time and more seat time
Old Dec 1, 2006 | 04:30 AM
quis84's Avatar
thanks i will but i probaly wont hit the track again till next season i think they all the northeast tracks are closing soon new goal for next season is 11.9
Old Dec 1, 2006 | 09:33 AM
nerdsports's Avatar
What psi did you have your tires at??
Lower the 60' and you're set.
Old Dec 1, 2006 | 02:46 PM
quis84's Avatar
14psi cold i dont know what its goes up to after the burn out how much does track temp effect your traction it felt like it was i the low 40's high 30's out side
Old Dec 1, 2006 | 04:22 PM
STEELCITYEVO8's Avatar
yeah man better 60' and u will see a drastic improvement. ur speed is good for lowlow 12's high 11's so ur power/weight is working for ya. sticky tires and a lsd
Old Dec 2, 2006 | 04:47 AM
quis84's Avatar
yea i am looking into slicks now but i dont know wether to get 23's or 24's i have the feeling 22's will be to small for me
Old Dec 2, 2006 | 07:21 AM
a1320addict's Avatar
what tranny are you using?
Old Dec 2, 2006 | 10:01 AM
quis84's Avatar
cable ls tranny
Old Dec 2, 2006 | 10:02 AM
22's will definently be too small, with the mph i'd say a 23" would be good? correct me if i'm wrong?
Old Dec 2, 2006 | 10:26 AM
quis84's Avatar
yea on the 205 i kept mssing 5th gear and that proablly was hurting my times as well i did not want to ride the limiter in 4th so i tried 5th but missed it both times
Street_Sleeper11
Sep 13, 2007 12:15 PM
domestic_rice
Nov 7, 2005 11:48 AM
0ptimus prime
Jun 17, 2005 09:14 PM
pushinlsteg
Nov 30, 2004 08:18 AM
streetlvlhatch
Apr 23, 2004 07:29 AM
