how do you adjust idle???
Old May 9, 2002 | 05:59 PM
khoalie's Avatar
Default how do you adjust idle???
i disconnect my idle contol motor and the engine goes up and down like mad and i turning the screw doesn't seem to affect it in any way.
i something wrong with my car or am i just retarded?
please help
Old May 9, 2002 | 06:23 PM
BreakStuff's Avatar
New User
Default Re: how do you adjust idle??? (khoalie)
Is the car at normal operating temperature when attempting this procedure?
Old May 9, 2002 | 09:22 PM
PWRVTEC's Avatar
Default Re: how do you adjust idle??? (BreakStuff)
You also have to trip the service connector under the dash.....
Old May 10, 2002 | 01:01 PM
khoalie's Avatar
Default Re: how do you adjust idle??? (PWRVTEC)
yes the car is warmed up till the fan turns on
how do i trip the service connector??
what does it look like?
thanks for the replys
Old May 10, 2002 | 01:55 PM
speedymon's Avatar
I assume you have a teg....It's under the dash on the passenger side. Somtimes inside a green rubber things. Take a paper clip and stick it in the two holes of the connector. Like sticking a fork in a wall socket.
Old May 11, 2002 | 06:50 AM
khoalie's Avatar
Default Re: how do you adjust idle??? (speedymon)
no i don't have a teg, that avatar is that v10 teg some1 photochopped
yeah i have a 94 del sol si
is it the same on my car?
thanks
DAmunster671
Oct 22, 2012 01:01 PM
..::91TEG-G2::..
Jun 15, 2004 11:19 AM
DJ_SaNdOz
Mar 4, 2003 08:34 AM
TurBoTeG
Nov 19, 2001 04:56 PM
