Civic Alternator and Underdrive Pulleys
Old Nov 29, 2006 | 09:02 PM
kornerk12's Avatar
Default Civic Alternator and Underdrive Pulleys
Does a civic alternator use a 6 rib belt as the prelude does ? Also are the underdrive pulleys interchangable ?
Old Nov 29, 2006 | 09:21 PM
mgags7's Avatar
No and No
Old Nov 29, 2006 | 09:22 PM
LudaChris's Avatar
Default Re: Civic Alternator and Underdrive Pulleys (kornerk12)
No, the civics use a V belt.
Old Nov 29, 2006 | 09:27 PM
Hawkze_2.3's Avatar
Default Re: Civic Alternator and Underdrive Pulleys (LudaChris)
My D-series alt has a 3-rib pulley & belt which will and does work with my 5-rib UR H23 crank pulley.
I really doubt the alternator pulleys are interchangable.
Old Nov 30, 2006 | 07:48 AM
kornerk12's Avatar
Default Re: Civic Alternator and Underdrive Pulleys (Hawkze_2.3)
So you would need a civic underdrive pulley. The belt that fit the prelude crank pulley should fit a regular civic alternator pulley or underdrive ?
Old Nov 30, 2006 | 08:06 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">So you would need a civic underdrive pulley. The belt that fit the prelude crank pulley should fit a regular civic alternator pulley or underdrive ? </TD></TR></TABLE>
You would need a pulley for whatever alternator you have...B, D, etc
No the belt won't fit...how would it? Prelude belt is either a 5 or 6 rib belt plus the length is going to be different (than the one you would need for a Civic alt).
Underdrive pulleys on the accessories don't really do anything anyway so don't worry about it.
Old Nov 30, 2006 | 08:47 AM
kornerk12's Avatar
Would a b or d series crank pulley work ? Would I need to modify anything ?
Old Nov 30, 2006 | 08:54 AM
Hawkze_2.3's Avatar
Ok, sorry if I mislead you...I thought we were talking about accessory pullies.
Use a H22/23 crank pulley with either D-alt/D-belt or B-alt/B-belt (don't think they have a B-series alt kit but whatever ). A belt with less ribs will work with a pulley with more ribs than the belt. That make sense?...
Old Dec 5, 2006 | 05:52 PM
kornerk12's Avatar
Actually the stock pulley on the alternator is a 6 rib so im fine there which is good. My question now is will it plug up ? The green plug and ring terminal that went on my stock prelude alternator should work on the civic one correct ?
The part number is 31100-PLM-A02RM.
Old Dec 6, 2006 | 12:13 PM
kornerk12's Avatar
bump
Old Dec 6, 2006 | 12:17 PM
mgags7's Avatar
Yes it will plug up, according to everyone I have asked so far it works fine
Old Dec 6, 2006 | 12:23 PM
kornerk12's Avatar
Default Re: (bb4ever)
Also its a 70 amp vs the stock h22 which i believe is a 90 correct ? You think i will have any problems ? I have no stereo just a flip screen and jdm fogs are the only extra draw.
Old Dec 11, 2006 | 09:26 PM
Hawkze_2.3's Avatar
Default Re: (kornerk12)
As I understand it, The plug will work fine as long as the OBDs are the same (OBD1, OBD2). So a 95 or earlier Civic alt will plug up to any 95 or earlier wiring harness, and vice-versa. Correct me if I'm wrong...
Old Dec 12, 2006 | 07:24 AM
.BigSexy's Avatar
most hood white kid
is this point of the d-series alt. a weight issue? or merely cospmetic to have a little les items visible in the bay...
and how did you get the d alt. to mount to the h22/23?
Old Dec 12, 2006 | 07:44 AM
skunked's Avatar
Default Re: Civic Alternator and Underdrive Pulleys (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">is this point of the d-series alt. a weight issue? or merely cospmetic to have a little les items visible in the bay...
and how did you get the d alt. to mount to the h22/23?</TD></TR></TABLE>
less weight, less drag and gives more room for different header designs and turbo stuff.
http://www.explicitspeedperformance.net
Old Dec 12, 2006 | 08:27 AM
.BigSexy's Avatar
most hood white kid
Default Re: Civic Alternator and Underdrive Pulleys (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">less weight, less drag and gives more room for different header designs and turbo stuff.
http://www.explicitspeedperformance.net </TD></TR></TABLE>
thanks for the info
slowpro
Oct 3, 2008 07:23 AM
mickiemagik
Mar 29, 2007 04:11 PM
incubus
Mar 10, 2004 08:33 PM
