windshield washer "switch" not working, pls help...
Old Nov 29, 2006 | 08:41 PM
dakers01's Avatar
Default windshield washer "switch" not working, pls help...
just moved to denver, colorado (from NW Arkansas) and am in the midst of my first snowstorm in years. that said, i am in need of help with a instrument problem. thanks in advance.
my car = 1995 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve
my windshield washer "switch" -- located on "control stick" protruding from the right side of the steering column -- has gone limp. this "control stick" is similar to the one on the left side of the steering column used to operate the turn signals. the righthand "control stick" has 3 functions: a) twist clockwise & counterclockwise to operate the windshield wipers @ OFF, INT, LO, HI b) press the stick downward to initiate a single swipe of the windshield wipers and c) pull the stick towards the driver to engage the washer fluid sprayheads on the hood.
"c" is where my problem lies. the righthand control stick used to have some tension when i would pull it towards me, but not long ago the stick went slack. and thus, i cannot wash my windshield. this is especially problematic as the snow and ice build up...i cannot clear my windshield and cannot see.
any advice/guidance you can offer to help me resolve this issue would be greatly appreciated. thanks again.
Old Dec 6, 2006 | 07:30 PM
hondadude's Avatar
Default Re: windshield washer "switch" not working, pls help... (dakers01)
You'll need to replace the switch assy. The little **** on the end of the stalk has broken loose.
So you escaped From NW Arkysaws huh? I'm hoping to move away from this *** backwards place the first of the year.
Old Dec 7, 2006 | 01:21 PM
dakers01's Avatar
Default Re: windshield washer "switch" not working, pls help... (hondadude)
yeah, i finally escaped NWA...was a long time coming. where u headed when u move?
thanks for ur help on this, i am headed to the parts store now...i will report back when i have installed the new switch assembly. out of curiousity, will the new assembly include a new stalk as well?
Old Dec 11, 2006 | 09:42 AM
dakers01's Avatar
my washer fluid jets are now operating again...and this was an easy install. thanks for ur help.
empi99
Dec 4, 2015 12:15 PM
Thorgs
Apr 15, 2008 12:14 PM
schillage
Feb 26, 2008 03:32 PM
Kevedge
Aug 19, 2004 01:40 AM
