FS- 88 Integra 3dr Bay Area, California $1200
88 LS 5 spd, 205,XXX miles. Runs excellent, 30+ mpg, just passed smog, registered until 8/2007, many extra parts, new carpet, minimal rust, but burns 1/2 to 1 quart of oil every 400 miles. Checked compression, 190 across...
$1200 firm
VIN# JH4DA3356JS005389
http://smg.photobucket.com/alb...SALE/
FOR SALE
1988 Acura Integra LS, 205K miles
Red with grey int, 2 door, 5 spd, PS, A/C (doesn’t work)
Engine: 1.6L, K&N panel filter, Poly engine mount insert, 2.5” exhaust with Summit Racing high flow muffler (looks and sounds stock), red silicone hoses
Trans: poly shifter bushings, Centerforce Dual Friction clutch
Interior: Stock, SE steering wheel, gauge lights tinted blue-green, new carpet and mats
Suspension: stock t-bars and springs, Tokiko HP’s, new tie-rod ends
Brakes: Brembo blanks (front), stock turned discs (rear), Axxis pads front and rear, Steel braided lines front and rear
Body: stock
ICE: stock
Car includes some extras like service manual, Haynes manual, all paperwork, new spare cat, spare Yoko Avid H4, original Acura touch up paint, and many extras! Clean Carfax!
Now for the bad stuff…. There is the usual rear wheel well rust, rust around the inside of the rear hatch, paint fade on the top of the driver fender and driver door, some small scratches and door dings. The engine runs great and gets 33mpg on average, but burns ½ to 1 quart of oil every 400 miles. It has an occasional grind in 3rd gear only when shifting quickly. The A/C will not hold a charge. The rear defroster doesn’t work (wire disconnected from glass). It probably needs new LCA's as well. It still has the originals.
<u>1988 Acura Integra maintenance</u>
1-5-2000 @ 152,549mi.
Purchased Integra
1-12-2000
Fuel filter
1-24-2000
Spark plugs
1-25-2000
New C/V boots
Pcv valve
1-27-2000 @ 153,336mi
4 new tires
1-30-2000
Air filter
Fan belts
2-3-2000
New hatchback lift supports
8-29-2000
MSD spark plug wires
9-1-2000
New catalytic converter
12-8-2000
New red vaccum lines
3-1-2001
New exhaust and muffler
8-23-2001
Poly motor mount insert and poly shifter bushings
8-25-2001
O2 sensor
8-29-2001
Cap
4-13-2002 @ 168,600mi
Replaced clutch, water pump, timing belt, accessory belts, hoses, radiator cap, thermostat, trans fluid, and coolant flush
11-3-2002
Cap and rotor
11-12-2002 @177,700mi
Replaced alternator (Pep Boys)
12-15-2002 @ 178,800mi
Replaced distributor and alternator (OEM)
12-20-2002
Moroso spark plug wires
Spark plugs
3-14-2003 @ 181,649mi
4 new tires
7-8-2003 @ 187,521 mi
Spark plugs
8-5-2003
4-3-2004 @ 191,571mi
New Brembo front rotors, turned rear rotors, new Axxis pads
4-27-2004 @ 191,621mi
Adjusted valves, new cap and rotor
4-28-2004
New exhaust and Summit racing muffler
8-13-2004 @ 193,150mi
Changed trans fluid
9-25-2004 @ 194,533mi
Stainless brake lines, bled brakes
1-11-2005 @ 195,718mi
Rotated tires
1-13-2005 @ 195,773mi
2 new tires
7-12-2005
New catalytic converter, O2 sensor
9-22-2005 @ 199,970mi
Rotated tires, new tie rod ends
5-15-2006
New carpet and mats
11-26-2006 @ 205,142mi
Rotated tires
There are many others that weren't documented, but this is all I could find. I have most of the receipts. Oil was changed on a regular basis; at least every 4 months or 4000 miles.
For faster response, please email me at seventnova@yahoo.com
Modified by 88LS at 10:00 PM 12/9/2006
$1200 firm
FOR SALE
Body: stock
ICE: stock
Purchased Integra
1-12-2000
Fuel filter
1-24-2000
Spark plugs
1-25-2000
New C/V boots
Pcv valve
4 new tires
1-30-2000
Air filter
Fan belts
2-3-2000
8-29-2000
9-1-2000
12-8-2000
3-1-2001
8-23-2001
8-25-2001
O2 sensor
8-29-2001
Cap
11-3-2002
Cap and rotor
12-20-2002
Spark plugs
4 new tires
Spark plugs
8-5-2003
4-28-2004
Changed trans fluid
Rotated tires
2 new tires
7-12-2005
5-15-2006
New carpet and mats
Rotated tires
CRXB5
Aug 27, 2011 03:11 PM
BlownSihatch
Sep 21, 2008 06:13 PM
