My car is Fawked, anyone help?
Old May 9, 2002 | 05:33 PM
AcuraRacer112's Avatar
Default My car is Fawked, anyone help?
Ok here is what's up:
1. I posted a couple of days ago of how my engine sounds like the hottest 1-4 turbo diesel around, couldn't figure out why? Thought it was due to oil change needed etc.. it was https://honda-tech.com/zerothread?id=180991 here it is if you want to read it.
2. I noticed I have no power in 1st or 2nd gear, 3rd and 4th and 5th are fine for power. ie. merging on to a highway, i have to use second (not saying I ever use first gear) to merge on the highway for one exist i take regularly.
3. My buddy WRXRacer111(fellow HT member) got home from schol (from U of Miami) today, he is my resident tech. I asked him about the noise he could not pin point it. first problem
4. So we take it for spin.
5. I also mention to him that I have no power in first and second gear, he was like what?????second problem
6. I show him, he was dumbfounded even after he drove the car and he is a far superior driver than me...there was no AC on at the time no, fans other than the ones need for the enging running. Nothing excessive was in the car etc...
There was a def. lack of power in first and second. We could only thing that it was a cylinder timing was off, or an injector was not working, or the fuel system was not really working properly. For this reason...I acidently put 89octane in now i am back at 93octane.
However The ECU should compensate for this right?? This is what I was told/know.
7. ONe top of all this my syncros are probably fawked in my tranny, hard as shyt to get into first and second from start and down shifting.
So my car = fawked IMHO
my car = 00 GS-r and yes I know about the warrenty I am going to take it in...just thought i would get some opinions TIA
Old May 9, 2002 | 05:42 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: My car is Fawked, anyone help? (AcuraRacer112)
try removing one plug wire at a time while the engine idles, one by one (replace each one before going to the next). each time the idle should get real rough or the RPM drop perhaps. If at any point you pull a plug wire and there is no change in idle, then that cylinder is dead, not getting any spark to ignite the fuel/air. It could be the plug, maybe the plug wire, maybe the dist. cap. I suppose perhaps if one cylinder is dead that the injector for that cylinder may not be working properly, but I'm not sure. HTH any.
Old May 9, 2002 | 06:13 PM
Goy091's Avatar
did you try a compression test?
Old May 9, 2002 | 06:16 PM
Default Re: My car is Fawked, anyone help? (Goy091)
nope going to get that done when i take it in
Old May 9, 2002 | 06:23 PM
Tanner's Avatar
New User
have you checked to see if you are throwig any trouble codes??
Old May 9, 2002 | 06:40 PM
Default Re: My car is Fawked, anyone help? (Tanner)
no codes at all
Old May 9, 2002 | 07:41 PM
ttt
Old May 9, 2002 | 09:15 PM
Rtzx9r's Avatar
GDD 1%
Warranty.
Old May 9, 2002 | 10:50 PM
jaybquick's Avatar
Default Re: My car is Fawked, anyone help? (Rtzx9r)
I have seen this when the cam timing is so far off that compression goes way off causing the engine to ping all the time (sounds like a diesel). Its a possibility, just my .02. Can you say Warranty
Old May 9, 2002 | 11:44 PM
Shingoblade-GSR's Avatar
Default Re: My car is Fawked, anyone help? (jaybquick)
Hey AcuraRacer112;
How many miles are on the teg?
Also, this is kind of off-topic, but why did you sell your 1000 hp pro street camaro?
Shingo
[Modified by Shingoblade-GSR, 12:45 AM 5/10/2002]
Old May 10, 2002 | 12:34 AM
B2FiNiTY's Avatar
Default Re: My car is Fawked, anyone help? (PatrickGSR94)
Do that.
Old May 10, 2002 | 06:18 PM
Default Re: My car is Fawked, anyone help? (B2FiNiTY)
Well my car has 13.5k on the odo.
I sold the camaro for lack of money, moving to a location with no garage space, umm and oh yeah my dad is an ******* nuff said.
mauriceoduor
Honda CR-V & Element
Jan 3, 2023 09:26 AM
Luke_Hanson
Apr 11, 2011 01:23 PM
T3T495GSR
Jan 14, 2006 07:38 AM
kay_animation
Jun 29, 2004 06:33 AM
