Water in all 4
I asked this question about a month ago and didnt get any good replys so let me try again.
I am getting water in all four cylinders. I would think that if it was a head gasket water would be in only one or two cylinders.
No water in the oil. no steam out of tail pipe.
Car has good power. Water seams to get in when when the car is off(I assume)...
engine = f22b
engine = f22b
Sure, seen that before it could be a cracked head or warped head that lets it come into all 4.
How much coolant is getting into the cylinders, we aren't talking about a minor condensation are we?
Hey Honda Dude,,
Thanks for the reply..... Once the engine is dry it starts easy and runs very good.... Doesnt look like and kind of condisation is coming out the exhaust pipe... its enough water to stop it from starting,,,,
So do you think I should pull the head and have it looked at....
Is there any other way the water could be getting in???
I thought maybe the Throttle body might be leaking and spraying all 4...
I just feel like it should be something commen to all 4 cyl...
I really hate to have to pull the head since I only have about 1000 miles on a complete rebuild..
Thanks Ron
Thanks Ron
if you have any muffler tape on the exhaust to stop a leak, take it off, you might find you're car shitting water when you try to start it if the hole is up high enough
this worked for my brothers grand am, sounds like you guys have the same problem, maybe it will work for you
