Distributor Problems.....engine:d15b vtec
Old Nov 29, 2006 | 05:31 PM
TougeGroceryGettR's Avatar
Default Distributor Problems.....engine:d15b vtec
Hi, im Joe, new to the forums but not to the site...
my problem:
i have a 96 civic 4door dx i swapped in a obd1 d15b vtec in because of a blown engine...(i still need a p28 ecu and vtec seliniod and conversion harness but thats not the problem) i got an obd1 distributor and wired it up according to the wiring diagram for the distributor...but for some reason there is no juice...it ran before with a rigged-up obd2 distributor... does this mean i need a new distributor? if so, whats a better bet? OBD1 or OBD2 distributor? should i just drill custom holes for the OBD2 distributor to fit? thanks in advance - Joe
Old Nov 29, 2006 | 05:34 PM
Jim Truett's Avatar
Default Re: Distributor Problems.....engine:d15b vtec (TougeGroceryGettR)
Just completely gut the OBD-2 distributor and install those components in the OBD-1 unit.
Old Nov 29, 2006 | 05:36 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">Just completely gut the OBD-2 distributor and install those components in the OBD-1 unit.</TD></TR></TABLE>
Do this because you fucked up your wiring. Put it back to where it was before you touch it, gut the internals of the dist and swap them over.
ej8_fredi
Mar 28, 2009 11:10 PM
Wheelman-CZ
Aug 12, 2007 01:53 AM
sitinthehall
Mar 18, 2007 08:01 AM
98JDM_Type_R
Aug 20, 2004 04:42 PM
Astr8upfella
Jan 20, 2002 01:30 PM
