Stock Injector
Old Nov 29, 2006 | 01:23 PM
bmanuhutu's Avatar
Default Stock Injector
Whats the stock injectors size for an LS , looked everywhere couldnt find em
and What would be a recommended injector size for FI, @ 8 PSI. Hopefully trying to reach 210-220 HP
Old Nov 29, 2006 | 01:28 PM
TrueUntilDeath.com's Avatar
Default Re: Stock Injector (bmanuhutu)
i think its 270cc stock
310cc comes with the greddy td05 18g kit and is capable of producing around 250whp if finely tuned
Old Nov 29, 2006 | 01:43 PM
HandleTech's Avatar
Unless you have done a V head swap or internal work (cams Pistons etc) your better off with your stock inj. If your running lean or plan on juicing it, get yourself an adjustable fuel pressure regulator and a fuel pressure gauge and turn it up 2 or 3 psi.
38-42 is stock fuel pressure.
Old Nov 29, 2006 | 03:51 PM
doood's Avatar
been there done that
Default Re: (FuknHeeHAw)
stock is 240cc
Old Nov 29, 2006 | 04:08 PM
2001B18C1GS-R's Avatar
and does anyone know 01 gsr injectors and h22 obd2 injector sizes thanks
Old Nov 29, 2006 | 04:12 PM
lVlemphizStylez's Avatar
Default Re: (2001B18C1GS-R)
all integra injectors are 240cc....regardless of trim..
Old Nov 30, 2006 | 12:34 AM
HandleTech's Avatar
Lude inj are somewhere near 300..
290 i believe...could be wrong though.
Good luck w/your 220 hp project.
Now is your goal to have that # to the floor..
or the flywheel?
Its neither easy or cheap to make hp...
Old Nov 30, 2006 | 04:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuknHeeHAw &raquo;</TD></TR><TR><TD CLASS="quote">
Its neither easy or cheap to make hp... </TD></TR></TABLE>
someone lied to you..its a honda..its pretty damn cheap to make hp compared to most platforms
Old Nov 30, 2006 | 06:20 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuknHeeHAw &raquo;</TD></TR><TR><TD CLASS="quote">Lude inj are somewhere near 300..
or the flywheel?
220 whp is a realistic goal for a turbo ls.
Old Nov 30, 2006 | 08:12 AM
bmanuhutu's Avatar
yea seen lotta ppl put down 240+ on stock block, with a proper tune
Old Nov 30, 2006 | 08:56 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R &raquo;</TD></TR><TR><TD CLASS="quote">and does anyone know 01 gsr injectors and h22 obd2 injector sizes thanks </TD></TR></TABLE>
http://www.allmotorhonda.com/t...r.htm
Old Nov 30, 2006 | 09:20 AM
dohcMONSTER's Avatar
Default Re: (that one doood)
all b series are 240, prelude is 290. Stock injectors are good up to ~200whp
Old Dec 7, 2006 | 11:11 AM
HandleTech's Avatar
Default Re: (lVlemphizStylez)
Compared to a v8, its more expensive...
and you get half the product..
And BTW, ive been lied to more than once!
Old Dec 7, 2006 | 11:12 AM
HandleTech's Avatar
FOr a turbo car.
220 should be easily reached..
i was under the impression it was an AM setup for some reason.
Old Dec 7, 2006 | 07:53 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuknHeeHAw &raquo;</TD></TR><TR><TD CLASS="quote">FOr a turbo car.
i was under the impression it was an AM setup for some reason.</TD></TR></TABLE>
what's an am setup?
raverx3m
May 10, 2020 11:58 PM
killerpenguin21
Apr 27, 2007 03:17 PM
OH_1fstgsr
Nov 10, 2006 12:15 PM
Boosted 01 SH
Mar 13, 2005 06:21 AM
Hybridhonda10
Apr 3, 2002 07:39 AM
